POV-Ray : Newsgroups : povray.unofficial.patches : Displacement mapping using isosurfaces Server Time
22 Jun 2026 23:52:54 EDT (-0400)
  Displacement mapping using isosurfaces (Message 1 to 10 of 12)
Subject: Displacement mapping using isosurfaces
Date: 10 Apr 2000 22:50:50
Message: <35434988.9770C3F4@hotmail.com>
Any chance of this being possible
TIA
Pabs
Subject: Re: Displacement mapping using isosurfaces
Date: 11 Apr 2000 01:10:51
Message: <38F2A5E8.88E8CD89@gci.net>
Yes.
> TIA
> Pabs
Date: 11 Apr 2000 03:46:30
Message: <38F2D7C6.159B42E4@hotmail.com>
"Mr. Art" wrote:
> Yes.
How Mr Art.
Pabs
Date: 11 Apr 2000 10:43:05
Message: <38F32C09.218C8C76@gci.net>
This short bit of code shows how to use a
planetary image as a displacement map on a sphere.
I had set it up as a macro to work with different
planet displacement maps, planet pigment maps, planet sizes,
and percentage displacements.
I know that this is displacement mapping only on a
sphere, but the same concept should work on other shapes.
I hope that this helps.
#macro PlanetMac(Pic1,Pic2,Rad,Prec)
	#local Pic= function{pigment {image_map {png Pic1 interpolate 2
map_type 1}}}
	#local R0=Rad;
	#local FUNC1=function {"sphere",<R0>}
	isosurface
		function{FUNC1(x,y,z)-(Pic(x,y,z)*R0*Prec)}
		contained_by {sphere {0,R0*(1+Prec)}}
		method 2 max_gradient 10
		pigment	{image_map{png Pic2 interpolate 2 map_type 1}}
		finish	{ blinn 1 facets .2 reflection 1 reflect_metallic
conserve_energy}
		interior{ior 20}
Pabs wrote:
> "Mr. Art" wrote:
> > Yes.
> How Mr Art.
> Pabs
Date: 11 Apr 2000 21:48:14
Message: <38F3D600.A087CAF2@hotmail.com>
I was thinking more along the lines of a patch which used isosurfaces to
implement displacement mapping
Date: 12 Apr 2000 01:09:58
Message: <38f40526@news.povray.org>
Pabs wrote in message <38F3D600.A087CAF2@hotmail.com>...
How about the following code:
#declare AnObject = union{
    sphere{<0,0,0>,1}
    torus{1.3,0.5}
#declare AnObjectFunc = pigment{
    object{
        AnObject
    color rgb 0, color rgb 1
isosurface{
    function{AnObjectFunc+noise3d(x,y,z)}
    contained_by{box{min_extent(AnObject),max_extent(AnObject)}
    method 2
    max_gradient 100
    pigment{rgb 1}
I can't guarentee that this will work on the first try, but it will displace
the surface of any object using the noise3d function.  To use a different
object, just replace AnObject with the object you want.
Mark
Date: 12 Apr 2000 02:13:46
Message: <38F40628.B1A10807@gci.net>
The syntax is all wrong for AnObjectFunc.
> #declare AnObject = union{sphere{<0,0,0>,1}torus{1.3,0.5}}
> #declare AnObjectFunc = pigment{object{AnObject} color rgb 0, color rgb 1}
> isosurface{
>     method 2
>     max_gradient 100
>     pigment{rgb 1}
> Mark
Date: 12 Apr 2000 04:00:24
Message: <38F42D25.B548445D@hotmail.com>
>     object{
>         AnObject
Are you sure this works - I don't think it will unless you are thinking about
the proximity pigment func
Date: 12 Apr 2000 08:19:27
Message: <chrishuff_99-BBDCFC.07220512042000@news.povray.org>
In article <38f40526@news.povray.org>, "Mark Wagner"
> displace
I think you mean:
#declare AnObject = union {
    sphere {<0,0,0>, 1}
    torus {1.3, 0.5}
function {
        object {AnObject color rgb 0, color rgb 1}
isosurface {
    function {AnObjectFunc(x,y,z)
        +noise3d(x,y,z)
    method 2
    max_gradient 100
    contained_by {box {min_extent(AnObject),max_extent(AnObject)}}
    pigment {color rgb <1,1,1>}
And the object pattern turns out to not be very good for
isosurfaces...it has two values separated by a sharp boundary, sort of
an infinite amount of slope. A boundary can appear anywhere, so the
isosurface algorithm has trouble finding them. And I don't think you
could displace the surfaces from within the function... I have a pattern
blurring feature I have been thinking of which might reduce this
problem, but I am not sure...
The proximity pattern might be helpful for this, but it is slow. You
might want to make a script that uses eval_pattern() to write the
results of proximity to a 3D density file, and use that in the
isosurface.
If your object is a blob, the blob pattern is useful. I have used it
before with very good results.
Also, don't forget that when the function goes through a pigment, you
can use warps like turbulence, black holes, etc to displace it. And with
function patterns and pigment functions, you can put any function
through a pigment. :-)
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 13 Apr 2000 22:42:18
Message: <38F685AA.158F04D9@hotmail.com>
I was thinking about it & came up with the attached image
This is explained as follows
1 the ray is traced to the surface normally
2 from the point of intersection take a point d (the displacement value for
that poin in space) units along the normal for that point of intersection
this is the center of a 5*5 rectangle of points used to make a bicubic
surface (or something like that)
3 the other points are found by tracing back to the surface and then going
up the normals
4 the ray is reflected off the bicubic surface
There are a lot of problems with this but it is a start
1 It will be slow (as slow/slower as/than proximity pigment??)
2 at small angles of intersection the ray may go under the surface and miss
it
maybe the points could be got by shooting from a point along the ray instead
3 when he ray doesn't hit the original surface (but it should hit the
displaced surface) this means that edges of an object will be smooth as the
original object - maybe we could use a proximity function added to a
displacement function and convert it to an isosurface... or we could just
tesselate the whole primitive into bicubic patches...
Download 'temp.gif' (4 KB)
Preview of image 'temp.gif'
