POV-Ray : Newsgroups : povray.unofficial.patches : Fix coredumps with pvmpov 3.5 Server Time
11 Oct 2026 02:58:15 EDT (-0400)
  Fix coredumps with pvmpov 3.5 (Message 1 to 4 of 4)
Subject: Fix coredumps with pvmpov 3.5
Date: 24 Sep 2004 11:55:31
Message: <20040924155226.GA7395@peter.daprodeges.fqdn.th-h.de>
since pvmpov still is version 3.1g from a FreeBSD port, I self-compiled
pvmpov 3.5. Unfortunately, this dumps core on my slave(s). I searched
for the reason and it turned out that the error occurs while trying to
init the display (which I thought I turned off by using -D on the
command line and Display=Off in global povray.ini).
The reason seems to be that ttyname(0) in unix.cpp's SVGAMode() returns
a NULL pointer (on FreeBSD 4.10-RELEASE-p3) which makes strstr() fail.
The attached patch checks for that so that I don't get coredumps anymore
and it works... ;-)
--- unix.cpp.orig	Fri Sep 24 15:40:44 2004
+++ unix.cpp	Fri Sep 24 15:33:02 2004
@@ -1838,7 +1838,7 @@
       return (false);
   /* if this isn't actually a TTY, no need for SVGA */
-  if (!strstr(ttyname(0), "tty"))
+  if (ttyname(0) != NULL && !strstr(ttyname(0), "tty"))
       return (false);
HTH & HAND,
  bye, Rocco
:wq!
Subject: Re: Fix coredumps with pvmpov 3.5
Date: 24 Sep 2004 12:19:56
Message: <4154492c$1@news.povray.org>
	This problem in 3.5 has been known for more than a year and
is fixed in the current 3.6 series.
http://news.povray.org/povray.unix/thread/%3C3ee306aa%241%40news.povray.org%3E/
	- NC
Date: 27 Sep 2004 09:39:51
Message: <20040927010203.GA15925@peter.daprodeges.fqdn.th-h.de>
Thanks for pointing this out. pvmpov still is based on 3.5 which is also
quite old... so I wonder if there're people using pvmpov at all (or if
there're better alternatives).
  bye, Rocco
:wq!
Date: 28 Sep 2004 11:28:29
Message: <4159831d$1@news.povray.org>
	I would personnaly prefer a MPI patch of 3.6 (over PVM, which,
to make it simple, is basically wasting one node).
	I'm not aware of such a port yet, 3.6 is still rather new.
Moreover the fundamental problems with e.g. the radiosity feature
are far from being solved.
	The best attempt towards improving the radiosity results on
multiple CPUs that I know of is in Francois "Wozzeck" Dispot's
PvMegaPOV patch:
http://www.wozzeck.net/images/pmp/
	which is another PVM patch based on MegaPOV 0.7 (therefore
it's older than POV 3.5 too, but more "featured" than 3.1g).
	- NC
