POV-Ray : Newsgroups : povray.unofficial.patches : ANNOUNCE: MegaPOV 1.0 available Server Time
12 Jun 2026 14:28:18 EDT (-0400)
  ANNOUNCE: MegaPOV 1.0 available (Message 51 to 60 of 67)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: ANNOUNCE: MegaPOV 1.0 available
Date: 2 Jan 2003 02:48:47
Message: <msp71v8a6018mhh2apioh9anqa6b7om4ov@4ax.com>
On Wed, 01 Jan 2003 21:01:45 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> > IE 5 Windows
> > Mozilla 1 Windows
> > Konqueror 3.0.1 Linux
> Indeed, a good selection of browsers for Mac users ;-)
Well, we have also txt version (it is in included dos archive) so there should
be no problem with the browser in that case ;-)
> Besides, if DocBook and XML are so good, why does the official documentation
> based on a proprietary system of extended HTML work so much better and on
> all browsers?  ;-) ;-) ;-)
That's not the problem of the DocBook idea but problem of rendering process. I
had not much time to customize all features available in free XSL stylesheets
and templates at http://docbook.sourceforge.net/projects/xsl/index.html. Also
I choosed xhtml as target for output for documentation. It is possible to use
'traditional' html. Please, verify:
html chunked: http://megapov.inetart.net/manual/html/index.html
html long: http://megapov.inetart.net/manual/html/megapov01.html
xhtml chunked: http://megapov.inetart.net/manual/index.html
xhtml long: http://megapov.inetart.net/manual/megapov01.html
I have checked xhtml output in validators but noticed only report about missed
alt and unnecessary "xmlns" attribute. Now I rechecked this and it seems
during development there appeared some duplicated ids. I have to investigate
it more. I have already found some bugs in free XSL files and some were fixed
for our release.
ABX
Date: 2 Jan 2003 03:04:04
Message: <for71v83s5ujpiidq3crdjuhkto6jv21a6@4ax.com>
On Thu, 02 Jan 2003 00:09:05 +0100, Nicolas Calimet <pov### [at] freefr> wrote:
> > And it also produces so much better PDF output... ;-)
>	Not really: see for instance page 19 of the current PDF docs,
> there are not PDF hyperlinks and no thumbnails in the file.
page 19 counting from first or page 19 counting from numbered as "1" ? :-)
In case of some urls there was no <ulink> tag applied. So I have to know what
tag you mean exactly to verify a bug. Please be more specific to help us make
it better.
>	Use PDFLaTex  ;op
Note, we are multienvironment team: windows (development tested on 95, 98, NT
and probably more), linux, mac (various versions) and we need effective but
uniform development. XSLT processors are easier to operate than TeX
environment. I could not force to work any of PDF outputs using TeX. I have
already looked for help with some experienced persons and could not find any.
But DocBook sources are available, if you have some experience, free time and
can provide tutorial how to do it for all mentioned platforms, please help us.
Any help in making MegaPOV documentation better either in appearance and
content is welcome.
ABX
Date: 2 Jan 2003 05:17:32
Message: <3e1411bc@news.povray.org>
In article <msp71v8a6018mhh2apioh9anqa6b7om4ov@4ax.com> , ABX
XHTML???  For what reason would any sane person use XHTML?  On the other
hand, if your goal is to break as many browsers as possible, using XHTML is
fine, of course.
Well, seems to work fine everywhere.  Except that Netscape 4.78 still
doesn't render the preformatted elements correctly.  I really wonder what
you did to break this?!?
    Thorsten
e-mail: tho### [at] trfde
Date: 2 Jan 2003 05:18:15
Message: <3e1411e7@news.povray.org>
Don't tell me that is all the testing you did???
    Thorsten
Date: 2 Jan 2003 05:37:18
Message: <3e14165e@news.povray.org>
> That would use huge amounts of memory, and I'm not sure how useful it
> would be. Using accumulation buffers would have big limitaitions, like
> only blurring things on objects seen directly.
Here is a simulated example (http://195.221.122.126/layers/layers.html) to see
what happens
i agree that
- it's probably useless for scene with lots of reflection/refraction
- it allows to tweak, and *fake* stuff (and this can sound like heresy to
ray-tracer integrists :)
M
Date: 2 Jan 2003 05:53:50
Message: <3E141A3D.FE36C24D@gmx.de>
> what happens
> i agree that
It is surely more difficult but with an object 'ID' output like Chris Huff
suggested you could generate a mask to post process only certain objects
(like blurring the floor reflection in your case) Of course this would
miss the indirect appearances of that object in other reflections etc. but
this is only relevant in some situations and can often be neglected.
It is out of question that post processing effects are not as good as
doing things internally but they have great speed advantages.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 2 Jan 2003 05:53:57
Message: <do481v8qf80s9tm16632nvel7sg7ei5c9m@4ax.com>
On Thu, 02 Jan 2003 11:17:30 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> fine, of course.
I don't remember exact reason why xhtml was used instead of html. I'm sure it
was becouse of some of several DocBook tutorials but can't recall url.
Everyone of us tested documentation versions on his native platform and it
seemed to work. I have also posted a link to you and you said nothing about
not readable pages, so I don't understand so much panic in your sentences :-)
It is a first release mostly concerned on building team, effective environment
and learning cooperation. It worked and we are happy about that. We can now
make it better. Would you like to provide some references according to "sane
persons vs. XHTML" ?
Then it will be changed probably in the future.
Nothing intentionally :-)
ABX
Date: 2 Jan 2003 05:56:54
Message: <3E141AF6.22F104EB@gmx.de>
> > fine, of course.
> seemed to work.
I have compared html and xhtml versions with Netscape 4.x (which is the
only relevant Browser i could test causing problems) and there were no
differences in the result.
Date: 2 Jan 2003 05:59:41
Message: <8h681vsehuqtq66qtnk145c02vqcntqnuj@4ax.com>
On Thu, 02 Jan 2003 11:18:14 +0100, "Thorsten Froehlich" <tho### [at] trfde>
As it already appeared in this thread several browsers were checked.
ABX
Date: 2 Jan 2003 07:46:23
Message: <3e14349f$1@news.povray.org>
In article <do481v8qf80s9tm16632nvel7sg7ei5c9m@4ax.com> , ABX
Try this, the problem is the same for all of the links you provide, unless
of course the examples are supposed to look this way?
<http://mac.povray.org/md.gif>
> Would you like to provide some references according to "sane persons vs.
> XHTML" ?
Well, I do with this post. This message completely compiles with long
standing RFC MIME specifications. I hope you get the point now.
Download 'utf-8' (2 KB)
