POV-Ray : Newsgroups : povray.unofficial.patches : ANNOUNCE: MegaPOV 1.0 available Server Time
12 Jun 2026 11:08:39 EDT (-0400)
  ANNOUNCE: MegaPOV 1.0 available (Message 38 to 47 of 67)
Subject: Re: ANNOUNCE: MegaPOV 1.0 available
Date: 1 Jan 2003 07:29:47
Message: <3e12df3b@news.povray.org>
> Interesting idea! But in what layer would a reflection of a refraction
> belong to?
we could do this only for primary rays, or have an option to give the trace
level we want
M
Date: 1 Jan 2003 07:59:20
Message: <3E12E628.2FE290DD@gmx.de>
> belong to?
I think they should be a separate layer.  The whole idea sounds very
interesting but would involve quite significant changes on source level so
it seem a rather large project.
Applications would be things like all kinds of selective blurring, for
example higher quality post processed focal blur (blurring the
reflection/refraction layers separately).
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 1 Jan 2003 12:43:35
Message: <cjameshuff-5CE547.12392201012003@netplex.aussie.org>
In article <3e12c8dd$1@news.povray.org>, "Mael" <mae### [at] hotmailcom>
wrote:
> it also would be great to have an option to output an image as multiple
> layers , a layer for each kind of contribution : diffuse, highlights,
> reflection, refraction, radiosity, photons, media ..etc So we can do
> compositing in post process (blur a reflection, add glow only on highlights,
> increase radiosity brightness, and so on without the need to re render)
That would use huge amounts of memory, and I'm not sure how useful it
would be. Using accumulation buffers would have big limitaitions, like
only blurring things on objects seen directly. Storing the ray trees
would use an impractical amount of memory...maybe in a decade, but by
then we probably won't need such tricks.
A single precision float usually takes 8 bytes. Assume we are using
those for everything, sacrificing some precision, a tree node is:
3 floats for ambient
3 floats for diffuse
3 floats for highlights (you could probably combine all types into this
one color, I don't think separate values for different types would be
useful)
3 floats for reflection
5(?) floats for pigment and transparency (assuming we keep the current
system...I think we shouldn't.)
2 node pointers (8 bytes each) for transmitted and reflected rays (it
could be many more, but I'll assume only two)
1 float for depth
3 floats for intersection point
3 floats for normal
3 floats for ray origin
3 floats for ray direction
30 floats and 2 pointers: 256 bytes for one node. The number of nodes
possible is 2^max depth. At the default of 7, that's 128 nodes, or 32KB
for one pixel sample. At 1024*768, that's 32MB a line, 24.6GB total.
Assuming no antialiasing and a lot of reflective transparent shapes. If
there is no transparency or reflection, only 192MB. And the overhead of
managing all that would probably destroy any benefits, especially when
using antialiasing.
http://tag.povray.org/
Date: 1 Jan 2003 13:21:49
Message: <3e1331bd$1@news.povray.org>
> would be.
I wasn't talking about saving the whole rays history.. Just adding options
to output one or more kind of pixel contribution (diffuse, radiosity,
photons, etc) as a separate image. Exactly as in the post-process patch ,
but instead of keeping depth, normal, etc we'll keep diffuse, highlights, or
whatever the user asks for. So i don't think the memory overhead would be
too important.
Now you're right maybe those separate layers will not be that useful
M
Date: 1 Jan 2003 14:13:50
Message: <cjameshuff-1738CC.14093701012003@netplex.aussie.org>
In article <3e1331bd$1@news.povray.org>, "Mael" <mae### [at] hotmailcom>
> too important.
My point was that you do need the ray tree to get full use of it.
Otherwise you have to accumulate the data in a 2D buffer or only use the
primary rays...not that helpful, and making it optional would add (a
little) overhead even when you aren't using the feature.
I think these buffers about strike the right balance:
Raw color values (unclipped, antialiased)
first intersection depth
first intersection point
first intersection normal
first ray origin
first ray direction
object "ID" (internally object pointer)
136 bytes per pixel if all are used, a max of about 102MB for a 1024*768
image. More reasonable, and enough for almost anything. A minimum of
18MB for just the color information. (for comparison, a 24-bit
uncompressed image of the same size would be 2.25MB)
I'm not sure if the other buffers should be antialiased as well...it
doesn't really make a lot of sense, and would slow rendering.
You could get rid of ray direction and depth or intersection point,
direction and depth can be calculated from origin and point, point can
be calculated by direction, origin, and depth. The max memory could go
down to 78MB. This makes more calculation later on though, keeping them
means faster filters.
You could also use fixed point, especially for normal and direction,
where there is a definite range of component values.
Date: 1 Jan 2003 14:47:47
Message: <3e1345e3$1@news.povray.org>
In article <cja### [at] netplexaussieorg> ,
Not that it changes anything about your valid argument, but (IEEE 754)
single precision floating-point numbers still take only four bytes, not
eight.
    Thorsten
e-mail: tho### [at] trfde
Date: 1 Jan 2003 15:01:58
Message: <3e134936@news.povray.org>
In article <3E12B6DE.431E9AC3@gmx.de> , Christoph Hormann
<chr### [at] gmxde>  wrote:
> Yvo already explained the Mac specialties - it looks fine on:
> IE 5 Windows
> Mozilla 1 Windows
> Konqueror 3.0.1 Linux
Indeed, a good selection of browsers for Mac users ;-)
And the W3C once noted that IE 5.x for Mac would be very close to their HTML
and CSS recommendations.  I would provide you with a reference, but somebody
at W3C accidentally or intentionally set the <www.w3.org/MarkUp/> content
type to "application/xhtml-xml", and as IE 5.0 for Mac OS does not support
XML it is successfully locked out from this part of the W3C website...
> but it has serious problems with Netscape 4.x
Of course, as said, I didn't expect it to work.
The real problem is that Mac OS ships with IE and the Apple Help viewer.  So
it is reasonable to expect the help to work properly with at least one of
the two rather than forcing a multimegabyte download.
Besides, if DocBook and XML are so good, why does the official documentation
based on a proprietary system of extended HTML work so much better and on
all browsers?  ;-) ;-) ;-)
    Thorsten
Date: 1 Jan 2003 15:19:55
Message: <3E134D6B.5804DC6F@gmx.de>
Thorsten Froehlich wrote:
> > IE 5 Windows
> > Mozilla 1 Windows
If you buy me a Mac i will also be able to supply information on that...
I really can't help much there.  Have you tried if it is better without
the style sheet?  If yes (like with NS 4.x) this would mean the problem is
in some style sheet definition.
And it also produces so much better PDF output... ;-)
Chistoph
Date: 1 Jan 2003 15:20:40
Message: <3E134D98.AB151D51@gmx.de>
> first ray origin
> first ray direction
As explained in my other post dividing the pixel colors into the different
contributing parts (i.e. reflected, refracted and direct, possibly split
into different parts) would be useful for post processing.
I think you are right to point out the memory problems.  This was a major
problem already in the original post processing patch - post processed
focal blur on a print size render was quite difficult.  Maybe it could be
avoided to have the data for the whole image in memory.  For just writing
the data to a file for processing in external programs this should not be
difficult but for internal operations this is of course quite tricky.
Date: 1 Jan 2003 16:00:14
Message: <cjameshuff-A0CA2D.15560101012003@netplex.aussie.org>
In article <3E134D98.AB151D51@gmx.de>,
And as I explained, I don't think that would be useful enough. Aside
from the memory problems, it is too special purpose and limited, too
complex, and has too much impact on other things. I don't see any
practical use for it. Saving the ray tree would be far more useful, but
has monstrous memory requirements.
