POV-Ray : Newsgroups : povray.unofficial.patches : Some musings about Motion blur, per-object post-processing, and more Server Time
16 Mar 2026 20:39:33 EDT (-0400)
  Some musings about Motion blur, per-object post-processing, and more (Message 1 to 10 of 11)
Subject: Some musings about Motion blur, per-object post-processing, and more
Date: 5 Nov 2000 00:19:33
Message: <01c046e8$7b2122a0$777889d0@daysix>
Chris, Nathan, I've been thinking.  I will try and express some ideas here,
and if I am unclear, please, ask.
Here they are:
Motion Blur:
Currently there are only two ways to do MB with Pov.  Both are exceedingly
slow.  What I propose is to make the motion_blur a post-process function.
What I mean is this:  say you have an object.
object {
funkyspaceship
and you want to blur it - however it moves. K, do this.
object {
funkyspaceship
motionblur {1,1}
the first number is how much blur there is per second number (a povray
distance unit).
Anyway, when this is rendered out, the program does a alpha-map of only the
object you want to blur.  The program then uses the alphamap as a selection
and blurs the actual image accordingly.  What I'm thinking of is a radial
blur much like the one in Photoshop.  The program would comput where the
focal point of the blur needed to be, according to the direction of the
object in the scene.
This method certainly isn't perfect, but it would provide a fast, easy to
use MB for Pov-Ray users.
Per-Object Post-Processing:
Uses much the same methods as the MB.  For every object with a pp tag, a
alphamap is generated while the render progresses.  These are all saved the
the harddrive, not kept in memory.  Then these alphamaps are used to
determine what area of the image gets what effect. Then the alphas are
deleted. Pretty simple, eh?
My only question to you is:  Can you make this work? Is it even doable?
TIA!
H.E. Day
Subject: Re: Some musings about Motion blur, per-object post-processing, and more
Date: 5 Nov 2000 07:33:03
Message: <chrishuff-34D768.07361505112000@news.povray.org>
In article <01c046e8$7b2122a0$777889d0@daysix>, "H. E. Day"
> only the object you want to blur.  The program then uses the alphamap
> as a selection and blurs the actual image accordingly.  What I'm
> thinking of is a radial blur much like the one in Photoshop.  The
> program would comput where the focal point of the blur needed to be,
> according to the direction of the object in the scene.
I don't think radial blur would give the best effect, unless I am
misunderstanding what you mean. And this would only work for objects
moving in a straight line...you would still have to use Nathan's patch
to do spinning objects. And it wouldn't work with reflections, objects
behind transparent objects, objects coming from behind other objects,
shadows, etc...
It should be possible, but I don't know how useful it would be.
> tag, a alphamap is generated while the render progresses.  These are
> all saved the the harddrive, not kept in memory.  Then these
> alphamaps are used to determine what area of the image gets what
> effect. Then the alphas are deleted. Pretty simple, eh?
No need to use an alpha map for this, just store a pointer to the object
that was hit first(sort of a single "object map" instead of possibly
hundreds or thousands of individual alpha maps). However, the code will
have to be altered so the objects aren't destroyed until after the post
processing is done. Nathan has been planning on doing something like
this, I don't know where he has gotten with it.
Christopher James Huff
Date: 5 Nov 2000 12:29:02
Message: <3a0598de@news.povray.org>
H. E. Day <Pov### [at] aolcom> wrote:
: What I propose is to make the motion_blur a post-process function.
  Then it would only be possible to use for objects moving parallel to the
viewing plane (ie. their distance to the camera does not change) and facing
the camera exactly in the same way all the time.
  No rotations nor size changes nor movements in the depth-direction nor
color or shape changes or anything else. Also if the object is reflected on
other object, the reflection will not be blurred (the same goes for
refraction/transparency). Also if the object is partially transparent, the
scene seen through this transparency will be wrongly blurred.
Date: 6 Nov 2000 10:13:53
Message: <3a06cab1@news.povray.org>
the
Why per-object?  Why not per-pigment or even per-color!  Much more flexible,
I think...
ZK
http://www.povplace.be.tf
Date: 6 Nov 2000 16:13:31
Message: <chrishuff-64E723.16133106112000@news.povray.org>
In article <3a06cab1@news.povray.org>, "Zeger Knaepen"
> flexible, I think...
Objects are on/off, it is there or it isn't, which means POV only has to
decide whether or not to do a filter. Pigments can blend, which would be
difficult get right, if it even makes sense. Even if something like this
is done, I think controlling it with the pigment would be a very bad
idea...some kind of post_process_map texture element would be better.
As for colors...that would probably be useless in nearly all cases,
since you may hit that same color somewhere in your image where you
don't want that post process filter done, and once you do anything like
fog, media, or anything that alters the appearance of an ambient 1
texture, it will no longer be recognized.
Object controlled filters would be easier to use, lower in memory
use(you only need one object map instead of a bunch of alpha maps),
easier to code, and just make more sense.
Date: 8 Nov 2000 01:47:26
Message: <3a08f6fe@news.povray.org>
It doesn't always need to make sense to be useful!
Maybe...  Doesn't really matter where you put it, I think...
No, that's not what I was trying to say :-)
Instead of telling POV to post-process all rgb <1,.5,.2> areas for instance,
'just' add a color-component, like rgbp <1,.5,.2,1>.
I don't think it would make more sense.  If you want to save memory, or
don't really like the in-between values, you can always say that a
post_process_map value of 0 would be no post_processing, and a value
different of 0 would be full post_processing.
But doing it object-controlled would be a lot less flexible and useful than
per-color or per-pigment pp.
Example: say I'm modelling a big spaceship.  Instead of modelling each
window, I like to fake them with texture_maps.  To make things look more
realistic, each lit window should be glowing a bit.  With per-object pp, I
should really model the windows, which would render a lot slower and use
more memory than texture_maps, but it would be no problem with per-pigment
pp.
ZK
Date: 8 Nov 2000 17:02:28
Message: <chrishuff-97AA5E.17023108112000@news.povray.org>
In article <3a08f6fe@news.povray.org>, "Zeger Knaepen"
But it *does* have to make sense in order for someone to implement it!
I suppose you could "branch" the post process stage into several
results, one for each filter, and interpolate between them, but this
would be very memory intensive.
> instance, 'just' add a color-component, like rgbp <1,.5,.2,1>.
Oh, I see what you mean. Not a color, just another channel. This sounds
similar to the post_process_map I was thinking of.
Object controlled filters would use less memory.
> or don't really like the in-between values, you can always say that a
> useful than per-color or per-pigment pp.
> each window, I like to fake them with texture_maps.  To make things
> look more realistic, each lit window should be glowing a bit.  With
> per-object pp, I should really model the windows, which would render
> a lot slower and use more memory than texture_maps, but it would be
> no problem with per-pigment pp.
I'd say you should use an object controlled post process and model the
windows anyway. Actually, a simple transparent box at each window
position would work, you wouldn't have to model anything, just make a
"signal object" in the right places to tell the post_process filter to
work.
A texture controlled filter wouldn't be cheap in memory, and if it
allows "blending" of filters, it would really eat memory and be
difficult to code.
Date: 9 Nov 2000 07:22:38
Message: <3a0a970e@news.povray.org>
That's how I used to do it: modelling the windows...  But that was way too
slow!
> work.
Maybe, but what about more complex shapes?
Example: let's say I'm trying to model the birth of a planet.  A planet with
parts of it still hot and glowing, and parts of cold stone.  I would use a
pattern so I can easily give the glowing parts a different texture.  With
per-object post-processing, I really don't know how I should do this...
> difficult to code.
But if it doesn't allow blending, I don't see why it would need more memory
than per-object based PP...?  One extra bit per pixel: post-process this
pixel or not.  Same as per-object PP.
ZK
Date: 10 Nov 2000 17:37:59
Message: <chrishuff-6620F9.17380610112000@news.povray.org>
In article <3a0a970e@news.povray.org>, "Zeger Knaepen"
> way too slow!
Slow rendering, or slow modelling?
> planet with parts of it still hot and glowing, and parts of cold
> stone.  I would use a pattern so I can easily give the glowing parts
> a different texture.  With per-object post-processing, I really don't
Use eval_pattern() or eval_pigment() to place spheres or some other
fast-redering shape(or glows, which won't even need a post_process
filter) at the right places? Use an isosurface as the target
object?(Probably too slow...)
Or just use media...
> memory than per-object based PP...?
It would require a separate "post process map" for every filter
controlled by a pigment, for one thing. And by removing the ability to
blend between filters, you remove a most of the reason for having
pigment controlled filters in the first place!
> post-process this pixel or not.  Same as per-object PP.
Wrong. At bare minimum, it would require storing some sort of post
process filter ID, to specify *which* filter to run. Probably a pointer,
unless you want to limit the number of filters you can use. Much more
than "one extra bit".
Date: 11 Nov 2000 17:11:09
Message: <3a0dc3fd$1@news.povray.org>
> > way too slow!
Uhm...
Both!
I didn't say it would be impossible to do so, I said it would be a lot
easier to have an effect_map.
Aand per-object based PP wouldn't need that?
 I know, but I thought you said blending the PP would be too difficult.
OK, but that's a choice every user can make for themself...  I mean: if you
include the option to do a global PP, it wouldn't always need this amount of
memory, only if the user wants it to.  Or am I wrong again?
ZK
