POV-Ray : Newsgroups : povray.unofficial.patches : Shadowless spotlights, Server Time
17 Mar 2026 02:18:16 EDT (-0400)
  Shadowless spotlights, (Message 11 to 17 of 17)
Subject: Re: Shadowless spotlights,
Date: 3 Aug 2000 16:36:07
Message: <3989D792.8CC89312@yahoo.com>
> I think you are right...area lights only affect shadows, the shading is
> the same as for point lights.
is this true?  i thought area lights were made of several point lights.
if what you are saying is true, than if my area light is bigger than my
object (a sphere for example) the light side is only one hemisphere
instead of more than a hemisphere?  that seems wrong to me.  take the
following sketches for further example:
0----0----0----0<---area light           0 <--point light
        0<-sphere                        0<-sphere
in example one it seems to me that light from the outer edges of the
area light should get farther underneath the point light than in example
two.  example two should light less than one hemisphere and example one
should light way more than a hemisphere.  in my opinion, if this isn't
how it works, it's wrong and should be fixed.
Date: 3 Aug 2000 17:23:11
Message: <slrn8ojpdc.9fi.ron.parker@fwi.com>
That's not how it works.  That's even not how it's documented to work:
|  The area_light keyword in POV-Ray creates sources that are rectangular
|  in shape, sort of like a flat panel light. Rather than performing the
|  complex calculations that would be required to model a true area light,
|  it is approximated as an array of point light sources spread out over
|  the area occupied by the light. The array-effect applies to shadows only.
|  The object's illumination is still that of a point source. The intensity
|  of each individual point light in the array is dimmed so that the total
|  amount of light emitted by the light is equal to the light color specified
|  in the declaration.
If you want "real" area lights, use an array of point lights.  Be aware that
that will make your render time a lot slower; so would "fixing" the current
implementation.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 4 Aug 2000 03:23:03
Message: <398A6F2E.A4AE4F8A@yahoo.com>
so that should mean there are self shadow errors because parts that
would be lit be a real area light aren't lit and can't cast shadows
right?  and what about parts that aren't lit that would contribute to a
cast shadow on another object?  i've read the docs over and over, but
you know you always catch something new each time, and i just hadn't
caught what you quoted to me.  thanks.  i still wish it worked right.
i'll have to keep point arrays in mind for the future.
Date: 4 Aug 2000 03:43:13
Message: <398A7259.A2F7A324@pacbell.net>
It works exactly how it was designed to work.
Date: 4 Aug 2000 09:37:13
Message: <slrn8oliel.hi.ron.parker@fwi.com>
Neither of those is a concern.  Shadows work correctly.  They're designed to.
Date: 4 Aug 2000 11:32:51
Message: <398AE1FE.C3F54F86@yahoo.com>
that's good to know and i appreciate all of the insight.
Date: 4 Aug 2000 11:42:07
Message: <398AE453.CF097941@aol.com>
More importantly, ask yourself the question: Is it partially shaded or
partially lit?  Just so happens that both are true, so there's no point
in calculating both.
Only thing that is missed are 100% accurate soft highlights, but
highlights are faked anyway so that's a moot point. :D
-Mike
