POV-Ray : Newsgroups : povray.unofficial.patches : Megapov post_process save_file format : Megapov post_process save_file format Server Time
17 Nov 2025 11:01:33 EST (-0500)
Date: 11 Jan 2011 06:00:00
Message: <web.4d2c3703162a5787a8dd583f0@news.povray.org>
Hello everyone,
I'm using this macro :
#version unofficial MegaPov 1.21;
#macro make_depth(max_depth, min_depth, file_name)
global_settings{
        post_process {
                PP_Init_Depth_Output()
                function { (f_output_depth(x,y)-min_depth)/(max_depth-min_depth)
                function { 1 }
                save_file file_name
to compute the distance to first intersection.
Everything is working allright, and I get my distance as a png image, with 256
grayscale.
Problems come on the next step : 256 grayscales are not precise enough.
Is there a way to change the format in which the save_file command saves the
image ?
I tried to write the distance into a formatted txt file, which would be
acceptable, but I need to get a float from f_output_depth(x,y), and this seems
to be a vector or color expression.
If this is documented somewhere, I dont find it...
Thanks for helping
