POV-Ray : Newsgroups : povray.unofficial.patches : Compile error during Megapov XRS server make : Re: Compile error during Megapov XRS server make Server Time
2 Apr 2026 03:43:09 EDT (-0400)
Date: 18 Nov 2006 21:25:01
Message: <web.455fbfafe1423b92c0bad8570@news.povray.org>
"Peter Raeth" <pet### [at] junocom> wrote:
> Am having a problem getting Megapov XRS server make to complete
> successfully. It generates several compile errors.
> Running the latest full cygwin on WinXP-Pro x64 v2003sp1 on a system with
> AMD Athlon 64x2 dual core processor 4200+.
> Downloaded and unpacked megapov-xrs_core-1.2.1-2.1.1.tar.bz2. Accomplished
> Step 0 and verified with:
> praeth@PRAETH-PC
/cygdrive/c/program_files/cygwin/tmp/megapov-xrs_core-1.2.1-2.1.1/megapov-xrs_server-1.2.1-2.1.1
> $ pkg-config --modversion libiqxmlrpc
> 0.7.3a
> Steps 1 and 2 went smoothly.
> Step 3 went through the configure process without error.
> Step 3 failed during the make process due to several compile errors:
> g++: unrecognized option `-pthread'
> xrs_serverthread.cpp: In member function `void
> xrs_gjp::rpc::ServerThread::operator()()':
> xrs_serverthread.cpp:74: error: expected primary-expression before '>' token
> xrs_serverthread.cpp:75: error: expected primary-expression before '>' token
> xrs_serverthread.cpp:76: error: expected primary-expression before '>' token
> xrs_serverthread.cpp:77: error: expected primary-expression before '>' token
> xrs_serverthread.cpp:78: error: expected primary-expression before '>' token
> xrs_serverthread.cpp:79: error: expected primary-expression before '>' token
> xrs_serverthread.cpp:81: error: expected primary-expression before '>' token
> xrs_serverthread.cpp:82: error: expected primary-expression before '>' token
> xrs_serverthread.cpp:83: error: expected primary-expression before '>' token
> make[3]: *** [xrs_serverthread.o] Error 1
> make[3]: Leaving directory
`/cygdrive/c/program_files/cygwin/tmp/megapov-xrs_core-1.2.1-2.1.1/megapov-xrs_server-1.2.1-2.1.1
> source/patches'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> source'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> make: *** [all] Error 2
> Many thanks for whatever insights you may have.
Hi Peter, I'm still puzzled because that's the compile error you'd get when
using the unsupported 0.8.x libiqxmlrpc, but you're using the correct
0.7.3a version.. what's your g++ version? Mine is:
themaxx@megatron ~
$ g++ --version
g++ (GCC) 3.4.4 (cygming special) (gdc 0.12, using dmd 0.125)
Copyright (C) 2004 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Thanks,
George
> Best,
> Peter.
