POV-Ray : Newsgroups : povray.unofficial.patches : Megapov XRS distributed rendering, initial release. Could use some guinea p= : Re: Megapov XRS distributed rendering, initial release. Could use some guin= Server Time
22 Mar 2026 20:50:17 EDT (-0400)
Date: 29 Aug 2006 12:05:00
Message: <web.44f465588dc3fb0cda5ae7f0@news.povray.org>
"George Pantazopoulos" <go### [at] tomyaboutpage> wrote:
> The segfault on the 64-bit system is pasted below. So far, I've been unable
> to find out why this happens. However I did suggest running with "-D" in
> the command line to see if not calling POV_Std_Display_Init() will avoid
> the segfault...
> Thread 1 (Thread 46912502363168 (LWP 4740)):
> #0  0x0000003757374600 in strlen () from /lib64/libc.so.6
> #1  0x000000375735e5ee in fputs () from /lib64/libc.so.6
> #2  0x00000000004350d6 in pov::POV_Std_Display_Init (w=Variable "w" is not
> available.
> ) at userdisp.cpp:66
> #3  0x000000000041797a in pov::FrameRender () at rendctrl.cpp:772
> #4  0x0000000000417e2c in pov::FrameLoop () at rendctrl.cpp:346
> #5  0x00000000004126f5 in povray_cooperate () at povray.cpp:598
> #6  0x000000000040bb8d in main (argc=Variable "argc" is not available.
> ) at unix.cpp:3096
> Kill the program being debugged? (y or n)
> George
FYI we discovered this could be avoided if the server is run with the "-D"
option. The display should always be disabled anyway. Going to fix this in
the next update. Thanks Jaime!
George
