POV-Ray : Newsgroups : povray.unofficial.patches : read pov scene text from RAM instead of disk file : Re: read pov scene text from RAM instead of disk file Server Time
7 Apr 2026 02:24:33 EDT (-0400)
Date: 23 Aug 2016 18:10:21
Message: <57bcc9cd$1@news.povray.org>
Am 23.08.2016 um 22:11 schrieb LanuHum:
> "Mr" <nomail@nomail> wrote:
>> Hi!
>> Is there a way for official pov or any other branch/patched verion, to read a
>> pov scene from Python string in RAM...?
>> (either directly or maybe using something like this?
>> http://docs.python.org/3/library/io.html#io.StringIO  )
>> Instead of having to write and read from the text file to disk, it would
>> probably make my exporter much faster for small scenes.
> It is not required. Required to render an external file instead ate
> one-dimensional array of string variables.
> char *povfile[] = {"#version", "3.7", "background","{","color"...and so on};
> As the file can be written in one line, and the python can transmit the exact
> same string.
> Developers only need to specify how to count?
> From a file or from a file.
> Oh array in english is file? Your language does not even see the difference.
No, array in English is not file. It is not the language that fails to
see the difference, but your translation software :P
> I see a simple desire
Hmm... I guess one way to approach this could be to allow the source
"file" to be read from the standard input stream.
Up to now that wasn't a realistic option, because you can't rewind the
standard input stream, and therefore neither loops nor macros would work.
However, now that I've implemented cached macros, which works by parsing
from a memory buffer rather than a file, it would be comparatively easy
to apply the same mechanism to cache an entire file -- or the standard
input stream, for that matter.
Unfortunately that approach probably only works for a console version,
not the current Windows binaries. Reading from the standard input stream
in Windows GUI programs seems to be non-trivial.
