POV-Ray : Newsgroups : povray.unofficial.patches : Megapov post_process save_file format : Re: Megapov post_process save_file format Server Time
14 Jun 2026 22:26:21 EDT (-0400)
Date: 11 Jan 2011 14:22:13
Message: <4d2cade5@news.povray.org>
> Problems come on the next step : 256 grayscales are not precise enough.
> Is there a way to change the format in which the save_file command saves the
> image ?
I'm not so familiar with MegaPOV but you could check if
the hf_gray_16 keyword has any effect here. Otherwise, you
might consider using a gray color gradient texture instead
of depth post-processing and using regular image output.
> I tried to write the distance into a formatted txt file, which would be
> acceptable, but I need to get a float from f_output_depth(x,y), and this seems
> to be a vector or color expression.
Possibly you could output a second image where the
function is defined not as the depth but as 256.0 times
the remainder of depth when dividing by 1/256 (or something
like that), so you get a PNG with the lower 8 bits and can
combine afterwards using external tools.
