POV-Ray : Newsgroups : povray.unofficial.patches : Error trying to use MegaPOV 1.2 post_process : Re: Error trying to use MegaPOV 1.2 post_process Server Time
11 Nov 2026 03:43:03 EST (-0500)
Date: 2 Nov 2010 10:16:26
Message: <4cd01d3a$1@news.povray.org>
El Tue, 02 Nov 2010 06:28:33 -0400, ThomasR escribió:
> Thanks for the hint !
> I was able to reach the next error : the compiler now recognizes the
> post_process and the PP_Depth, but it stops in pprocess.inc (which I
> absolutely did not modify), in the macro :
> #macro _filter_depth(_f_in,_firld_start,_firld_depth)
> function{clip(adj_range2(_f_in(u,v),_firld_start,_firld_start
+_firld_depth,0,1),0,1)}
> #end
> The error message is "Parse error, expected 'operand', found vector
> identifier instead"
> It seems to come from "_f_in(u,v)"
> I don't understand what I did wrong. Did I give wrong inputs to PP_Depth
  Most likely, yes...
> I called the function this way :
> global_settings{
>      post_process{PP_Depth(<0,150,0>,150)}
  This seems a clear case of RTFM... :)
  I've just looked at
http://megapov.inetart.net/manual-1.2.1/megapov0121.html#inc_pprocess.inc
  and there I read "Field_Start specifies the beginning of the focal
range *IN UNITS* from the camera." ;)
Jaime Vives Piqueres
http://www.ignorancia.org
