POV-Ray : Newsgroups : povray.unofficial.patches : compiling megapov.. : Re: compiling megapov.. Server Time
20 Mar 2026 17:21:34 EDT (-0400)
Date: 11 Nov 2006 07:59:45
Message: <4555c941$1@news.povray.org>
> #0  0x00000038ec873cb0 in strlen () from /lib64/libc.so.6
> #1  0x00000038ec85dcae in fputs () from /lib64/libc.so.6
> #2  0x00000000004407a6 in pov::POV_Std_Display_Init (w=Variable "w" is not
> available.
> ) at userdisp.cpp:66
	OK, the problem was introduced in megapov and is simple to fix.
Edit the file source/userdisp.cpp and change the line 65 from:
	char *s = NULL;
to
	char *s = "";
and the segmentation fault should go away.  Do the same at lines 97 and 117.
	Even better, as the AVOID_EMPTY_STRING_WARNING megapov patch is quite
ugly IMHO, you may apply the following *untested* patch (the code should work,
but I cannot verify whether it will fill its purpose of avoiding a compiler
warning).  Paste the following into  patchfile  and apply the patch as:
patch -p0 < patchfile
% cat patchfile
--- userdisp.cpp.bak    2005-08-23 21:20:33.000000000 +0200
+++ userdisp.cpp        2006-11-11 13:57:09.000000000 +0100
@@ -62,8 +62,7 @@
    Prev_X = 0;
    Prev_Y = 0;
    #ifdef AVOID_EMPTY_STRING_WARNING
-    char *s = NULL;
-    fprintf(stderr, "%s", s);
+    fprintf(stderr, "%s", "");
    #else
      fprintf(stderr, "");
    #endif
@@ -94,8 +93,7 @@
  void POV_Std_Display_Close()
-    char *s = NULL;
    #else
    #endif
@@ -114,8 +112,7 @@
      Prev_Y++;
-    char *s = NULL;
    #else
    #endif
	Hope this helps,
	- NC
