POV-Ray : Newsgroups : povray.unix : compile error on Raspbian: Boost Thread library version not found Server Time
15 Mar 2026 12:45:05 EDT (-0400)
  compile error on Raspbian: Boost Thread library version not found (Message 1 to 7 of 7)
Subject: compile error on Raspbian: Boost Thread library version not found
Date: 9 Nov 2015 13:00:00
Message: <web.5640de07a8e6d3fe48dea6910@news.povray.org>
I am trying to compile POV-Ray on a Raspberry Pi 2. Master branch throws this
message when compiling and stops:
Libraries
checking whether to link with cygwin DLL... no
checking whether to enable static linking... no
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for boostlib >= 1.38... yes
checking whether the Boost::Thread library is available... yes
configure: error: Could not find a version of the library!
Any clues? I am kinda new to this. I always ran POV-Ray on windows.
Subject: Re: compile error on Raspbian: Boost Thread library version not found
Date: 9 Nov 2015 16:38:56
Message: <56411270$1@news.povray.org>
Hash: SHA256
Le 09/11/2015 18:55, MadKairon a écrit :
> Hi,
> throws this message when compiling and stops:
> Libraries --------- checking whether to link with cygwin DLL... no
> checking whether to enable static linking... no checking for the
> pthreads library -lpthreads... no checking whether pthreads work
> without any flags... no checking whether pthreads work with
> -Kthread... no checking whether pthreads work with -kthread... no
> checking for the pthreads library -llthread... no checking whether
> pthreads work with -pthread... yes checking for joinable pthread
> attribute... PTHREAD_CREATE_JOINABLE checking if more special flags
> are required for pthreads... no checking for boostlib >= 1.38...
> yes checking whether the Boost::Thread library is available... yes
> windows.
usually (well, with modern boost library), you might need to add
LIBS="-lboost_system -lboost_thread" to the parameters of config
Someothers did compile for the rasberry pi, so they might give better
help.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlZBEm8ACgkQhKAm8mTpkW1jRQQA2WsyTGbyH7Ob1ik2a0Q7KXZ2
6p7epvOVR/3Y8Ji/Sxihb+1P0kFN2nIem2ys+rSXgLoBlurqdjjebTiYm4TUiHRa
JqWodev86oBy6tQuSLNZKlxhOIRJWHyQYyNlZAWv/mXdU1J2S9T9yihY6qHrrKcN
Gh9tqzodEiu1MaiIvVI=
=WreH
-----END PGP SIGNATURE-----
Date: 9 Nov 2015 22:05:00
Message: <web.56415df8841b54df43f93d110@news.povray.org>
> help.
> Version: GnuPG v2
> =WreH
Tried adding those parameters to the config but did not work. No one has
compiled it with the modern boost nor latest versions of automake. Master Branch
solves the atomake problems tho.
Date: 13 Jun 2017 08:45:00
Message: <web.593fdd81841b54dfbbe07c920@news.povray.org>
> > help.
> > Version: GnuPG v2
> > =WreH
Tryin' to configure the compilation on raspberrypi (raspbian)
Same error:
Command
pi@raspberrypi:~/povray $ ./configure --prefix=$HOME/opt/povray
COMPILED_BY="MCL"  LIBS="-lboost_system -lboost_thread"
Libraries
checking for boostlib >= 1.37... yes
Any tips to solve this issue ?
Thx !
Date: 13 Jun 2017 10:25:22
Message: <593ff5d2@news.povray.org>
> Same error:
> Command
Is it the stable or master branch you are trying to compile ?
> Libraries
> Thx !
Date: 13 Jun 2017 12:06:34
Message: <59400d8a$1@news.povray.org>
> Same error:
> Command
> Libraries
> Thx !
Could you perhaps try adding an explicit pointer to the installed boost
library on the ./configure command? For me on Ubuntu this looks
something like:
./configure ... --with-boost-libdir=/usr/lib/x86_64-linux-gnu
on the Raspberry Pi the boost location will likely be different.
If you go to your <povrayRoot>/unix/config you should find a sym link
back to the automake config.guess script. Try to run it via
./config.guess and see what it returns.
If nothing reasonable, perhaps this the core issue on your set up.
Otherwise, see if the boost library is located in something like:
/usr/lib/<config.guess's return string>
you can use:
ls /usr/lib/<config.guess'a return string>/libboost*
to verify the archive (.a) and shared library (.so) boost files are there.
Aside 1 : Looks like our --with-boost[=ARG] build option isn't properly
set up and somewhat redundant by description with --with-boost-libdir.
Aside 2 : Curious, are any of you Pi folks looking at Pi clusters?
Bill P.
Date: 24 Jun 2017 17:14:14
Message: <594ed626$1@news.povray.org>
On 11/09/2015 12:55 PM, MadKairon wrote:
> Hi,
> Libraries
Reference github issue:
https://github.com/POV-Ray/povray/issues/300
User reported the following worked as a patch for the ./configure
failure in this thread:
./configure COMPILED_BY="Mausy5043"
--with-boost-libdir=/usr/lib/arm-linux-gnueabihf
Bill P.
