POV-Ray : Newsgroups : povray.unix : Povray 3.7.0 Crashing on Raspberry Pi Server Time
19 Dec 2025 05:25:33 EST (-0500)
  Povray 3.7.0 Crashing on Raspberry Pi (Message 1 to 6 of 6)
Subject: Povray 3.7.0 Crashing on Raspberry Pi
Date: 17 Mar 2015 21:50:00
Message: <web.5508d9839e40eea01b2ee8700@news.povray.org>
Hello
I've written a program called ArtRays that generates povray source files using
randomness. ArtRays generates the source file and then it execs povray (version
3.7.0) to render the image to a file and then ArtRays displays the file using
SDL.
I'm doing this on a Raspberry Pi2 with four cores and it is amazing fast.
Unfortunately ArtRays runs for a while and then povray crashes with the
following error:
povray: /usr/include/boost/thread/pthread/recursive_mutex.hpp:101: void
boost::recursive_mutex::lock(): Assertion `!pthread_mutex_lock(&m)' failed.
Anyone seen this before and maybe know of a fix?
Subject: Re: Povray 3.7.0 Crashing on Raspberry Pi
Date: 18 Mar 2015 04:01:35
Message: <550930df$1@news.povray.org>
Am 18.03.2015 um 02:48 schrieb Craig Lindley:
> following error:
That does /not/ sound good at all.
It indicates that for some reason the boost threads library doesn't work
properly.
There is no way this can be fixed in POV-Ray itself (short of using a
different multithreading library, which would be a major undertaking),
and the only thing you as a user can do about it (short of reporting the
problem to the boost developers and waiting for a fix) is minimizing the
probability that thread synchronization issues arise.
The most thread synchronization heavy component of POV-Ray is the
radiosity sample cache. If you're using radiosity and don't want to do
without, you might want to try UberPOV and its no_cache feature.
Date: 18 Mar 2015 23:50:01
Message: <web.550a46e47d046a731b2ee8700@news.povray.org>
> > following error:
> properly.
I am not using radiosity at all in ArtRays.
Date: 19 Mar 2015 12:55:01
Message: <web.550afe3c7d046a731b2ee8700@news.povray.org>
> > > following error:
> > properly.
I've updated the boost library to 1.50 and I'll see if that fixes things.
Date: 19 Mar 2015 22:50:01
Message: <web.550b89d17d046a731b2ee8700@news.povray.org>
> > > > following error:
> > > properly.
POVRay has now run for over two hours and has yet to crash. Version 1.46 of the
boost library might have been the issue.
Date: 20 Mar 2015 04:25:33
Message: <550bd97d$1@news.povray.org>
Am 20.03.2015 um 03:45 schrieb Craig Lindley:
Probably so. Thanks a lot for trying this out and sharing!
