POV-Ray : Newsgroups : povray.unix : Installation problem in povray subdivision on server. Server Time
4 May 2026 01:01:34 EDT (-0400)
  Installation problem in povray subdivision on server. (Message 1 to 10 of 12)
Subject: Installation problem in povray subdivision on server.
Date: 3 Aug 2014 06:45:01
Message: <web.53de12643d3a69d306240250@news.povray.org>
i installed povray with full source on server and moved the files of povray
subdivision(http://www.cise.ufl.edu/~xwu/Pov-Sub/) in source folder then i
installed povray on centos server. povray is working fine but povray subdivision
is not working.
when i using code below.
mesh2 {
subdivision{     // subdivision
     substeps 2    // subdivide 2 times
vertex_vectors {
its showing error.
Please help me to solve the installation issue.
Thanks
Suman
Subject: Re: Installation problem in povray subdivision on server.
Date: 3 Aug 2014 06:59:47
Message: <53de1623@news.povray.org>
On 08/03/2014 06:43 AM, Suman wrote:
> Hi,
> is not working.
> mesh2 {
> vertex_vectors {
> its showing error.
> Thanks
> Suman
you didn't say where you got povray source code ... what version? the
subdivision files were last updated in 2004 so if you used version 3.7
povray source code there may be incompatibilities ... MANY things have
changed since version 3.6
did you notice any compile errors when you added the subdivision files
to the povray source tree?
Date: 3 Aug 2014 07:20:04
Message: <web.53de19b33102494a306240250@news.povray.org>
Hi James,
i downloaded POV-Ray Source Code here
http://www.povray.org/download/index-3.6.php
and update the source files of povray subdivision
from(http://www.cise.ufl.edu/~xwu/Pov-Sub/).
i used the following command
../configure COMPILED_BY="your name <email@address>" [options]
  make check
  make install
but after installation subdivision is not working.
Thanks
Suman
> > Hi,
> > is not working.
> > mesh2 {
> > vertex_vectors {
> > its showing error.
> > Thanks
> > Suman
Date: 3 Aug 2014 07:27:07
Message: <53de1c8b$1@news.povray.org>
On 08/03/2014 07:14 AM, Suman wrote:
> Hi James,
>    make check
>    make install
Did you notice any errors or warnings from either the configure or make
process?
not working how ... does it even recognize any of the keywords
associated with the subdivision patch?
> Thanks
> Suman
>>> Hi,
>>> is not working.
>>> mesh2 {
>>> vertex_vectors {
>>> its showing error.
>>> Thanks
>>> Suman
Date: 3 Aug 2014 07:50:01
Message: <web.53de211d3102494a306240250@news.povray.org>
i did not notice any error during installation.
i am using exec command for image generation online.
exec("/usr/local/bin/povray ...");
and no error is showing.
> > Hi James,
> >    make check
> >    make install
> process?
> > Thanks
> > Suman
> >>> Hi,
> >>> is not working.
> >>> mesh2 {
> >>> vertex_vectors {
> >>> its showing error.
> >>> Thanks
> >>> Suman
Date: 3 Aug 2014 07:50:20
Message: <53de21fc$1@news.povray.org>
>> Hi,
>> povray
>> then i
>> subdivision
>> is not working.
>> mesh2 {
>> vertex_vectors {
>> its showing error.
>> Thanks
>> Suman
unless the subdivision patch is a /must/ you should consider moving to
version 3.7 ... here's a summary of what's changed:
http://wiki.povray.org/content/Documentation:Tutorial_Section_1#Changes_and_New_Features_Summary
Date: 3 Aug 2014 07:58:44
Message: <53de23f4$1@news.povray.org>
yeah ok then ... i'll ask again not working how? does it even recognize
any keywords associated with the subdivision patch ... do you even get a
complete render?
>>> Hi James,
>>>     make check
>>>     make install
>> process?
>>> Thanks
>>> Suman
>>>>> Hi,
>>>>> is not working.
>>>>> mesh2 {
>>>>> vertex_vectors {
>>>>> its showing error.
>>>>> Thanks
>>>>> Suman
Date: 3 Aug 2014 08:15:01
Message: <web.53de27363102494a306240250@news.povray.org>
when i run povray without subdivision code like
mesh2 {
 vertex_vectors {
then i can see image online. and when i use the subdivision code like
mesh2 {
 vertex_vectors {
then image not comes.
> complete render?
> >>> Hi James,
> >>>     make check
> >>>     make install
> >> process?
> >>> Thanks
> >>> Suman
> >>>>> Hi,
subdivision
> >>>>> is not working.
> >>>>> mesh2 {
> >>>>> vertex_vectors {
> >>>>> its showing error.
> >>>>> Thanks
> >>>>> Suman
Date: 3 Aug 2014 08:20:23
Message: <53de2907$1@news.povray.org>
> mesh2 {
>   vertex_vectors {
> mesh2 {
>   vertex_vectors {
you're not being specific enough ... does the program complete
successfully when subdivision is used
Date: 3 Aug 2014 08:40:01
Message: <web.53de2d153102494a306240250@news.povray.org>
> > mesh2 {
> >   vertex_vectors {
> > mesh2 {
> >   vertex_vectors {
its necessary because online renderer taking lots of time on server. and i did
not get complete package of povray with subdivision. may be some error in
subdivision files. therefore i am not able to generate image.
