POV-Ray : Newsgroups : povray.unix : Possible way(s) to install POV-ray on a cluster Server Time
5 Feb 2026 02:38:35 EST (-0500)
  Possible way(s) to install POV-ray on a cluster (Message 1 to 9 of 9)
Subject: Possible way(s) to install POV-ray on a cluster
Date: 2 Aug 2014 04:10:01
Message: <web.53dc9b9a7b1b3b9dce9901c40@news.povray.org>
Hi all,
I want to install POV-ray on a cluster of Debian machines.
Compiling POV-ray 3.7 worked very well, but now I don't know what is the best
option to use multiple nodes with POV-ray together.
Some projects like MPIPOV [1] or other projects [2][3][4] look dead. Broken
links, no update since >10 years...
[1] http://www.ce.unipr.it/research/parma2/povray/povray.html
[2] http://pvmpov.sourceforge.net/
[3] http://www.wozzeck.net/images/pmp/
[4] http://www.verrall.demon.co.uk/mpipov/
Approach 1-4 are all related to patches which are either not available any more
or look quite outdated and incompatible with POV-ray 3.7.
This approach [5] looks quite helpful because it is not related to any patches.
It just splits the image calculation by row.
[5] http://homepages.ihug.co.nz/~wrooney/present/povclust.html
What is the best option to create a POV-ray cluster?
Is there any project which makes use of MPI and is up to date?
Thanks for any help.
   Christian Baun
Subject: Re: Possible way(s) to install POV-ray on a cluster
Date: 2 Aug 2014 05:00:04
Message: <53dca894@news.povray.org>
Am 02.08.2014 10:05, schrieb Christian Baun:
Indeed, forget all of the above.
This approach is problematic with radiosity, creating visible artifacts
at the seams.
My personal suggestion would be to use UberPOV, with radiosity sample
caching disabled (effectively using stochastic sampling for diffuse
illumination), a different random seed on each machine, and letting all
machines render the very same complete scene. The resulting images can
then be averaged via imageMagick or the like to reduce the noise in the
images.
If you find any, let us know.
Date: 8 Aug 2014 15:40:00
Message: <web.53e526776b1b2e0950a09d050@news.povray.org>
Hi all,
I implemented two shell scripts (no MPI or PVM), which implement the
functionality I was looking for.
Here it is:
http://code.google.com/p/task-distributor/
Maybe you enjoy it.
Best Regards
   Christian Baun
Date: 8 Aug 2014 15:53:40
Message: <53e52ac4$1@news.povray.org>
Am 08.08.2014 21:35, schrieb Christian Baun:
> Hi all,
> Here it is:
> Maybe you enjoy it.
Nice job! Thanks for sharing.
Date: 16 Aug 2014 21:30:00
Message: <web.53f004e26b1b2e09fd3737aa0@news.povray.org>
clipka <ano### [at] anonymousorg> wrote> > What is the best option to create a
POV-ray cluster?
> images.
When/will this feature make it into main Povray?
Date: 17 Aug 2014 11:17:26
Message: <53f0c786$1@news.povray.org>
Am 17.08.2014 03:26, schrieb jhu:
>> images.
You mean the disabling of the radiosity cache?
I don't have the slightest idea. It quite certainly depends on whether
and when POV-Ray will embrace stochastic rendering in general.
Historically and at present, official POV-Ray prefers to avoid random
noise, but stochastic rendering doesn't fly without.
Date: 18 Aug 2014 15:50:00
Message: <web.53f258cb6b1b2e099a4676b00@news.povray.org>
> >> images.
Does this make Uberpov an unbiased renderer?
Date: 18 Aug 2014 20:36:15
Message: <53f29bff$1@news.povray.org>
Am 18.08.2014 21:49, schrieb jhu:
>>>> images.
Not entirely; for some stuff UberPOV still only provides POV-Ray's
biased algorithms; I haven't tackled media, dispersion and caustics yet,
and there might be more I haven't even thought of so far.
But yes, it is my intention for UberPOV to ultimately provide unbiased
algorithms for these effects as well. Alongside POV-Ray's biased
algorithms, allowing the user to choose whatever they prefer.
Date: 18 Aug 2014 23:55:01
Message: <web.53f2ca5f6b1b2e09d19b0ec40@news.povray.org>
Man, that'd be awesome! Is anyone else working on this or are you the only one?
