POV-Ray : Newsgroups : povray.unix : Modify source code of program POVRAY Server Time
5 Feb 2026 02:41:02 EST (-0500)
  Modify source code of program POVRAY (Message 1 to 5 of 5)
Subject: Modify source code of program POVRAY
Date: 27 May 2014 20:55:00
Message: <web.538533c76c8053922ebcdc450@news.povray.org>
Hello everyone,
I want to ask How we can open the source code of program POVRay?
If we can do it, we can see the flow proses rendering in POVRay and we can
modify that such we can add some coding (like MPI maybe) for get paralel
rendering program with POVRay.
Sorry, I am new in POVRay.
Galih Pribadi
Subject: Re: Modify source code of program POVRAY
Date: 28 May 2014 05:00:24
Message: <5385a5a8$1@news.povray.org>
Le 28/05/2014 02:54, gaprie nous fit lire :
> Hello everyone,
> Regards,
> Galih Pribadi
Parallel rendering on multiple cores is already supported (appeared with
3.7).
The license for version 3.7 is AGPLv3. Notice that the license for
previous versions were different.
The main problem for rendering on multiple hosts is sharing the memory
of the parsed scene (and its radiosity/photons data if any).
You can obviously fork from the git repository
 https://github.com/POV-Ray/povray
Many people already did it.
About the branches: 3.7-stable is the slowest one, equivalent to
released version. master is more reactive.
(there is two other branches, but you might stay away from them)
Date: 28 May 2014 11:11:16
Message: <5385fc94$1@news.povray.org>
Am 28.05.2014 11:00, schrieb Le_Forgeron:
>> Hello everyone,
>> Regards,
>> Galih Pribadi
> 3.7).
Photons isn't that much of a problem, since photon shooting can easily
be parallelized; you'd just need to distribute the results before the
main render begins.
Radiosity is a good deal trickier, as the original algorithm
theoretically requires fully sequential operation.
Date: 29 May 2014 20:50:01
Message: <web.5387d4fa4b0f921ad19b0ec40@news.povray.org>
How did you get around that? Whenever I render a scene with radiosity, all cores
are at 100% when calculating the radiosity data.
Date: 29 May 2014 22:26:16
Message: <5387ec48@news.povray.org>
Am 30.05.2014 02:46, schrieb jhu:
The problem is not in getting all cores busy, nor in the quality of the
results. The main challenge in radiosity is avoiding to do redundant
work - computing more radiosity samples than actually needed.
In a shared-memory system (such as your multi-core machine), it's not
really that bad: Any newly calculated sample is immediately made known
to all threads, so double work is only done if two threads happen to be
computing samples at roughly the same spot at the same time.
In a distributed-memory system however, there is a much longer delay
between a radiosity sample being finished and all the other processes
learning about it, so the risk of double work goes up - especially if
you want to prevent the network from being cluttered up by a torrent of
short messages, and send around finished samples in bigger packages.
Obviously the whole thing also won't scale very well, as each node must
keep each other node informed of their results.
Therefore, an entirely different approach is needed for the pretrace
phase, where render nodes don't need to know the whole picture to do
their part of the job.
