FreeBSD 10 uses clang instead of gcc. After the usual ./prebuild.sh,
../configure, etc.
[jhu@PhIIx6-1090T:~/temp/povray-3.7-stable]$ make
make all-recursive
Making all in source
c++ -DHAVE_CONFIG_H -I. -I.. -I.. -I../source/backend -I../source/base
-I../source/frontend -I../unix -I../vfe -I../vfe/unix -pthread
-I/usr/local/include -I/usr/include -pipe -Wno-multichar -Wno-write-strings
-O3 -ffast-math -march=native -D_THREAD_SAFE -pthread -MT pov_mem.o -MD -MP -MF
..deps/pov_mem.Tpo -c -o pov_mem.o pov_mem.cpp
In file included from pov_mem.cpp:36:
In file included from ./backend/frame.h:58:
In file included from ./backend/control/messagefactory.h:39:
../backend/control/renderbackend.h:112:16: error: reference to 'shared_ptr' is
ambiguous
map<SceneId, shared_ptr<Scene> > scenes;
.../vfe/unix/syspovconfig.h:85:14: note: candidate found by name lookup is
'shared_ptr'
using boost::shared_ptr;
/usr/include/c++/v1/memory:3817:24: note: candidate found by name lookup is
'std::__1::shared_ptr'
class _LIBCPP_TYPE_VIS shared_ptr
../backend/control/renderbackend.h:112:27: error: 'Scene' does not refer to a
value
../backend/control/renderbackend.h:47:7: note: declared here
class Scene;
../backend/control/renderbackend.h:112:34: error: expected member name or ';'
after declaration specifiers
../backend/control/renderbackend.h:113:15: error: reference to 'shared_ptr' is
ambiguous
map<ViewId, shared_ptr<View> > views;
'shared_ptr'
../backend/control/renderbackend.h:113:26: error: 'View' does not refer to a
value
../backend/control/renderbackend.h:48:7: note: declared here
class View;
../backend/control/renderbackend.h:113:32: error: expected member name or ';'
../backend/frame.h:982:3: error: unknown type name 'shared_ptr'
shared_ptr<SubsurfaceInterior> subsurface;
../backend/frame.h:982:13: error: expected member name or ';' after declaration
specifiers
In file included from pov_mem.cpp:39:
In file included from ./backend/parser/parse.h:63:
In file included from ./backend/scene/scene.h:45:
In file included from ./backend/scene/view.h:40:
../backend/support/taskqueue.h:60:15: error: unknown type name 'shared_ptr'
TaskEntry(shared_ptr<Task> rt) : entryT...
../backend/support/taskqueue.h:60:25: error: expected ')'
../backend/support/taskqueue.h:60:14: note: to match this '('
../backend/support/taskqueue.h:65:5: error: unknown type name 'shared_ptr'
shared_ptr<Task> GetTask() { return task; }
../backend/support/taskqueue.h:65:15: error: expected member name or ';' after
../backend/support/taskqueue.h:72:5: error: unknown type name 'shared_ptr'
shared_ptr<Task> task;
../backend/support/taskqueue.h:72:15: error: expected member name or ';' after
../backend/support/taskqueue.h:59:31: error: member initializer 'entryType' does
not name a non-static data member or base class
TaskEntry(EntryType et) : entryType(et) { }
../backend/support/taskqueue.h:60:38: error: member initializer 'entryType' does
...TaskEntry(shared_ptr<Task> rt) : entryType(kTask), task(rt) { }
../backend/support/taskqueue.h:60:61: error: use of undeclared identifier 'rt'
../backend/support/taskqueue.h:61:35: error: member initializer 'entryType' does
...TaskEntry(POVMS_Message& m) : entryType(kMessage), msg(m) { }
../backend/support/taskqueue.h:62:62: error: member initializer 'entryType' does
...boost::function1<void, TaskQueue&>& f) : entryType(kFunction), fn(f) { }
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
*** Error code 1
Stop.
make[2]: stopped in /tank/jhu/temp/povray-3.7-stable/source
*** Error code 1
Stop.
make[1]: stopped in /tank/jhu/temp/povray-3.7-stable
*** Error code 1
Stop.
I found this post:
http://news.povray.org/povray.macintosh/message/%3Cweb.527ba51a8e82598ec61fefd40%40news.povray.org%3E/#%3Cweb.527ba51a8
Seeing if this will solve the issue.
"jhu" <nomail@nomail> wrote:
> I found this post:
a8
That worked. Needed to change every instance of "shared_ptr" to
"boost::shared_ptr"
> > I found this post:
51
> a8
> "boost::shared_ptr"
d'oh! Looks like the binary is slower than the one compiled with gcc (slower by
about 10 seconds on the benchmark scene, clang 3.3 {freebsd 10.0} vs. gcc 4.2.1
{freebsd 9.2}). Oh well.
Le 06/03/2014 08:32, jhu nous fit lire :
From measurement on linux, gcc 4.7 / clang 3.3 (4.2.1), it depends on
the availability of HT.
gcc is better with HT, clang is better without. And icpc (intel
compiler) wins everytime.
Well, now this is interesting. Working on renders containing sslt, focal blur,
and radiosity. The clang compiled binary is 10 minutes faster than the gcc
compiled one (CPU: Phenom II x6 1090T; 2 hours 4 minutes for clang; 2 hours 15
minutes for gcc).
