Povray 3.7
1. Went into unix directory
2. ./prebuild.sh goes fine
3. cd to main directory
4. ./configure COMPILED_BY=" " ends up with:
checking which architecture to optimize for... x86_64-unknown-freebsd9.2 (using
-march=native)
Makefiles
stat: illegal option -- c
usage: stat [-FLnq] [-f format | -l | -r | -s | -x] [-t timefmt] [file ...]
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: error: cannot find input file: `Makefile.in'
Incidentally, it compiles fine in Debian 7.
Hmmmm... this is interesting.
If I run ./prebuild.sh on the Linux machine, then copy the entire directory over
to the FreeBSD machine, ./configure will run without a hitch. Unfortunately,
compiling via make will fail unless the following is done
CFLAGS="-Dlseek64" CXXFLAGS=$CFLAGS ./configure
which ends up with
g++ -DHAVE_CONFIG_H -DPOVLIBDIR=\"/usr/local/share/povray-3.7\"
-DPOVCONFDIR=\"/usr/local/etc/povray/3.7\"
-DPOVCONFDIR_BACKWARD=\"/usr/local/etc\" -I. -I.. -I../vfe/unix -I../unix
-I../source -I../source/base -I../source/backend -pthread -I/usr/local/include
-pipe -Wno-multichar -Wno-write-strings -fno-enforce-eh-specs -s -O3
-ffast-math -march=native -Dlseek64=lseek -D_THREAD_SAFE -pthread -MT
vfeplatform.o -MD -MP -MF .deps/vfeplatform.Tpo -c -o vfeplatform.o `test -f
'unix/vfeplatform.cpp' || echo './'`unix/vfeplatform.cpp
unix/vfeplatform.cpp: In member function 'virtual bool
vfePlatform::UnixShelloutProcessing::ExecuteCommand(const std::string&, const
std::string&)':
unix/vfeplatform.cpp:376: error: 'WEXITSTATUS' was not declared in this scope
*** [vfeplatform.o] Error code 1
Stop in /tank/jhu/temp/povray-3.7.0.0/vfe.
*** [all-recursive] Error code 1
Stop in /tank/jhu/temp/povray-3.7.0.0.
*** [all] Error code 1
Aha! Needed to add #include <sys/wait.h> in vfe/unix/vfeplatform.cpp
So, to compile on FreeBSD 9.2
1. ./prebuild.sh on a Linux system
2. copy entire directory to FreeBSD system
3. add #include <sys/wait.h> in vfe/unix/vfeplatform.cpp
4. CFLAGS="-Dlseek64=lseek" CXXFLAGS=$CLFAGS ./configure
Am 13.12.2013 04:08, schrieb jhu:
> Makefiles
This is a known issue with BSD-style systems, first reported for OS X;
see GitHub issue #7 for the problem, and how OS X people currently work
around it:
https://github.com/POV-Ray/povray/issues?state=open
You might also want to read issue #9, and maybe also #5 and #10.
The dev team have already looked into this, and made some code changes
that will hopefully address the problems, but that code hasn't made its
way into the Git repo yet.
> > Makefiles
> around it:
How about two prebuild.sh scripts, one for Linux systems and one for BSD
systems?
Am 14.12.2013 18:05, schrieb jhu:
>>> Makefiles
>> around it:
> systems?
The differences are comparatively minor, so having two scripts would
probably just add unnecessary maintenance overhead for the future. If
the fix we've come up doesn't work, the next best thing would probably
be a small conditional block in the prebuild.sh script, governed either
by some smart BSD-detection code or a simple script parameter.
