POV-Ray : Newsgroups : povray.unix : Povray 3.7.0 works fine on Slackware 14.0 x86_64 Server Time
4 May 2026 01:01:25 EDT (-0400)
  Povray 3.7.0 works fine on Slackware 14.0 x86_64 (Message 1 to 3 of 3)
Subject: Povray 3.7.0 works fine on Slackware 14.0 x86_64
Date: 15 Nov 2013 12:00:00
Message: <web.528651884f71d511380f8080@news.povray.org>
Just to report that the 3.7.0 works fine on Slackware.
Below is the recipe I used to build it if anybody is interested.
Note - I think a quirk of the newsgroup software makes lines starting
with . (one dot) become .. (two dots)
Cheers,
Peter
cd /media/space/software/Source/povray/povray-3.7.0/povray
git config core.sparsecheckout true
echo source/ >> .git/info/sparse-checkout
echo unix/ >> .git/info/sparse-checkout
echo vfe/ >> .git/info/sparse-checkout
echo distribution/ >> .git/info/sparse-checkout
echo doc/ >> .git/info/sparse-checkout
git remote add -f origin https://github.com/POV-Ray/povray
git pull origin master
#From https://github.com/POV-Ray/povray
# * [new branch]      3.7-stable -> origin/3.7-stable
# * [new branch]      master     -> origin/master
# * [new tag]         v3.7.0.0   -> v3.7.0.0
#Backup /media/space/software/Source/povray/povray-3.7.0/povray to
/media/space/software/Source/povray/povray-3.7.0/povray.tar.gz
cd unix/
../prebuild.sh
cd ../
../configure COMPILED_BY="petergardner" --with-boost-thread=boost_thread
#POV-Ray 3.7.0 has been configured.
#Built-in features:
#  I/O restrictions:          enabled
#  X Window display:          enabled (using SDL)
#  Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff openexr
#  Unsupported image formats: -
#Compilation settings:
#  Build architecture:  x86_64-unknown-linux-gnu
#  Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
#  Compiler vendor:     gnu
#  Compiler version:    g++ 4.7.1
#  Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread
#Type 'make check' to build the program and run a test render.
#Type 'make install' to install POV-Ray on your system.
#The POV-Ray components will be installed in the following directories:
#  Program (executable):       /usr/local/bin
#  System configuration files: /usr/local/etc/povray/3.7
#  User configuration files:   /home/dad/.povray/3.7
#  Standard include files:     /usr/local/share/povray-3.7/include
#  Standard INI files:         /usr/local/share/povray-3.7/ini
#  Standard demo scene files:  /usr/local/share/povray-3.7/scenes
#  Documentation (text, HTML): /usr/local/share/doc/povray-3.7
#  Unix man page:              /usr/local/share/man
make -j2
make check #the biscuit + coffee render fine
#As root
checkinstall # this does "make install" and also creates a Slackware package
#Edit 3 - Version to be 3.7.0
#This package will be built according to these values:
#1 -  Summary: [ povray ]
#2 -  Name:    [ povray ]
#3 -  Version: [ 3.7.0 ]
#4 -  Release: [ 1 ]
#5 -  License: [ GPL ]
#6 -  Group:   [ Applications/System ]
#7 -  Architecture: [ x86_64 ]
#8 -  Source location: [ povray ]
#9 -  Alternate source location: [  ]
Subject: Re: Povray 3.7.0 works fine on Slackware 14.0 x86_64
Date: 15 Nov 2013 12:22:27
Message: <52865853$1@news.povray.org>
glad to see my sparsecheckout post was helpful? well somewhat helpful
... as i noticed that the doc directory /still/ hasn't been flowed to
github. Did you notice an error because of that? I'll see what I can do
about applying a nudge in the appropriate place.
Date: 15 Nov 2013 14:30:00
Message: <web.5286753db8038259380f8080@news.povray.org>
Didn't notice any errors.
Cheers,
Peter
