POV-Ray : Newsgroups : povray.unix : PovRay-3.7.0.RC7 make error. Server Time
23 Dec 2024 07:54:01 EST (-0500)
  PovRay-3.7.0.RC7 make error. (Message 1 to 6 of 6)
Subject: PovRay-3.7.0.RC7 make error.
Date: 16 Mar 2013 17:50:01
Message: <web.5144e80bb7c5ef1ade1c639f0@news.povray.org>
I'm running Ubuntu 12.10, and after successfull configuration of PovRay source
code, I get this error after starting "make":
make[3]: *** [jpeg.o] Error 1
make[3]: Leaving directory `/home/maciej/install/povray-3.7.0.RC7/source/base'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/maciej/install/povray-3.7.0.RC7/source'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/maciej/install/povray-3.7.0.RC7'
make: *** [all] Error 2
Any ideas?
Subject: Re: PovRay-3.7.0.RC7 make error.
Date: 16 Mar 2013 18:46:26
Message: <5144f642$1@news.povray.org>
Am 16.03.2013 22:45, schrieb Rubid:
> Hi,
> Any ideas?
That's a pretty surprising one, because both the function signature and
the return value have been unchanged for years now, without any problem
reports.
Anyway, I have some hunch. Can you try replacing all occurrences of
"true" with "TRUE" in the file "image/jpeg.cpp"?
Date: 17 Mar 2013 06:05:01
Message: <web.5145947644c9fa6cde1c639f0@news.povray.org>
> > Hi,
> > Any ideas?
> reports.
Thanks clipka!
It worked like a charm! Can you tell me how did you figure it out?
For those who have the same problem:
sed "s/true/TRUE/g" jpeg.cpp > jpeg.cpp
Date: 17 Mar 2013 09:19:44
Message: <5145c2f0@news.povray.org>
Am 17.03.2013 11:01, schrieb Rubid:
> Thanks clipka!
Well, the error messages indicated that there was a problem with
conversion between the C++ standard data type "bool" and some other
non-standard data type named "boolean" in the file "image/jpeg.cpp",
which is the POV-Ray code that calls the jpeg library to read and write
JPG image files.
It was prudent to assume that the "boolean" data type was defined by the
jpeglib, as it's a plain C library, and C does not have the "bool" type.
I searched the jpeglib code for "boolean" to find out how the type is
defined, and found one location where it is defined as "unsigned char";
however, a comment in that piece of code indicated that this definition
was only used on Windows systems, so I followed some breadcrumbs and
found another definition that would be used on non-Windows systems; this
one defined the "boolean" type as an enumeration, with two values named
"FALSE" and "TRUE". At that same location I also found code that would
again be used on Windows systems, which would define two macros "FALSE"
and "TRUE".
 From what I found, I concluded that the proper "yes" value to pass into
a "boolean" type would be "TRUE" (both on Windows and Unix systems),
while the fact that "true" also worked fine on many systems could be
considered a mere coincidence.
The fix will also be included in the 3.7.0 release proper.
Date: 17 Mar 2013 10:34:24
Message: <5145d470$1@news.povray.org>
FYI: pulled #5867 ... even tho I /didn't/ have the OP's problem it
compiled just fine on my linux
Date: 17 Mar 2013 13:59:42
Message: <5146048e$1@news.povray.org>
Am 17.03.2013 15:34, schrieb James Holsenback:
I was quite sure it would ;-)
