POV-Ray : Newsgroups : povray.unix : I can see througt the display window on Ubuntu Server Time
16 Jun 2024 19:55:25 EDT (-0400)
  I can see througt the display window on Ubuntu (Message 1 to 5 of 5)
Subject: I can see througt the display window on Ubuntu
Date: 14 Dec 2012 11:30:01
Message: <web.50cb537b23e48f629f1e124f0@news.povray.org>
I have no idea where it comes from, I am a beginner but I have to use POV-Ray in
my C++ program. Does someone have an idea to fix this ?
I can't attach anything to this post so here is the image :
http://www.heberger-image.fr/data/images/59641_Capture_du_2012_12_14_17_15_51.png
The two round shadows are the display of the following image that I obtain in
the output file :
http://www.heberger-image.fr/data/images/30660_Capture_du_2012_12_14_17_22_18.png
I need to display what my program calculates, so I'm counting on the display
more than on the output file.
Here is my command line :
povray +P test1.pov
here is the POV file :
 location < -3.0, 3 , -3.0>
 up y
 look_at <0 ,0.2 ,0 > }
box {
 < -30.0 , -0.1 , -30.0 >,
 <  30.0 ,  0.0 , 30.0  >
 finish { ambient 0.0 diffuse 0.8 reflection 0.6 }
 pigment { color red 0.2 green 0.2 blue 0.3 }
light_source {
 <-10, 30, -40>
 color red 0.8 green 0.8 blue 0.8
sphere {
 <0 ,1 ,0 > , 1
 finish { ambient 0.0 diffuse 0.8 phong 0.0 }
 pigment { color red 1 green 1 blue 1 }
Subject: Re: I can see througt the display window on Ubuntu
Date: 14 Dec 2012 12:32:07
Message: <50cb6297$1@news.povray.org>
Le 14/12/2012 17:27, kissvcool nous fit lire :
It's seem it is povray 3.6.
Give a try to 3.7RC6 sources, it might have solved that X11 handling
already.
> the output file :
Once rendered, you can display the rendered image with your usual tool.
(eog, display, ...)
Date: 14 Dec 2012 14:00:01
Message: <web.50cb761af98b41f89f1e124f0@news.povray.org>
> already.
I'm trying to install this beta version, and following the instructions :
-1 : ./configuration
    a bunch of line appear and I can only guess that it must be ok.
-2 : make
    Nothing happens and I get the message :
in English ->
          No specified target and no makefile could be found. Stop.
I don't know if it's relevant but the files Makefile.am and Makefile.in are
there.
Date: 14 Dec 2012 15:17:02
Message: <50cb893e$1@news.povray.org>
Am 14.12.2012 19:55, schrieb kissvcool:
>> already.
That /should/ be "./configure"; and if you run it without any arguments,
you'll get some lines saying that you need to specify COMPILED_BY, i.e.:
     ./configure COMPILED_BY="John Doe (jdo### [at] foocom)"
You may also want to specify an installation directory via the "prefix"
option, such as:
     ./configure --prefix=/home/jdoe/povray37 COMPILED_BY="..."
"./configure" should ideally run a bunch of tests, printing plenty of
lines saying "Testing whether...: yes/no"; and finally explicitly tell
you that everything is ok, with a summary of the settings "make" will be
using.
It might complain though that some libraries are missing (you'll need
both the libraries themselves and the corresponging *-dev packages),
such as libboost, libpng, libjpeg, libtiff, and/or (optionally) openexr.
It's all described in the INSTALL text file though.
> -2 : make
> in English ->
> there.
After "./configure" has run (successfully), you should also find a
"Makefile" (without extension).
Date: 14 Dec 2012 16:40:50
Message: <50cb9ce2$1@news.povray.org>
   IIRC, this switch solved the problem: -visual DirectColor
Jaime
