![](/i/fill.gif) |
I built povray 3.7.0 beta 25b on Solaris and noticed the CPU time
accounting was wrong:
Render Time:
Photon Time: 0 hours 0 minutes 0 seconds (0.338 seconds)
using 7 thread(s) with 0.-07 CPU-seconds total
Radiosity Time: 0 hours 0 minutes 3 seconds (3.966 seconds)
using 4 thread(s) with 0.-04 CPU-seconds total
Trace Time: 0 hours 2 minutes 35 seconds (155.919 seconds)
This can be fixed by using getrusage(). A suggested source fix
is below. The CPU time in the output will then be correct:
Render Time:
Photon Time: 0 hours 0 minutes 0 seconds (0.430 seconds)
using 7 thread(s) with 1.349 CPU-seconds total
Radiosity Time: 0 hours 0 minutes 5 seconds (5.736 seconds)
using 4 thread(s) with 22.032 CPU-seconds total
Trace Time: 0 hours 3 minutes 18 seconds (198.617 seconds)
using 4 thread(s) with 782.070 CPU-seconds total
--- ./vfe/unix/platformbase.cpp Tue Mar 25 21:50:49 2008
*** 196,202 ****
--- 196,206 ----
#endif
#ifdef HAVE_GETRUSAGE
struct rusage ru;
+ #if defined(__sun)
+ if (getrusage(m_ThreadTimeOnly ? RUSAGE_LWP : RUSAGE_SELF, &ru) == 0)
+ #else
if (getrusage(RUSAGE_SELF, &ru) == 0)
+ #endif
return (unsigned POV_LONG) (1000)*(ru.ru_utime.tv_sec + ru.ru_stime.tv_sec)
+ (unsigned POV_LONG)(ru.ru_utime.tv_usec + ru.ru_stime.tv_usec)/1000;
#endif
*** 226,231 ****
--- 230,242 ----
if (clock_gettime(CLOCK_THREAD_CPUTIME_ID, &ts) == 0)
return true;
#endif
+ #ifdef HAVE_GETRUSAGE
+ struct rusage ru;
+ if (getrusage(RUSAGE_LWP, &ru) == 0)
+ return true;
+ #endif
+ #endif
return false;
![](/i/fill.gif) |
