POV-Ray : Newsgroups : povray.unix : rendering options Server Time
27 Sep 2024 19:40:56 EDT (-0400)
  rendering options (Message 1 to 3 of 3)
Subject: rendering options
Date: 14 Sep 2007 10:45:00
Message: <web.46ea9d48b374e3a67c492ce20@news.povray.org>
   I'm trying to figure out how use anti-aliasing with povray on linux and I
can't find any documentation on this.  I don't know if this is standard, but
I use a shell to render images.  So command line:
povray file_name.pov +W1280 +H960
To use anti_aliasing how would I modify this command, and specify a
threshold and all that?
 Thanks,
        Sebastian
Subject: Re: rendering options
Date: 14 Sep 2007 14:14:02
Message: <46eacf6a$1@news.povray.org>
On Fri, 14 Sep 2007 10:41:20 -0400, Sebastian wrote:
man povray gives (among other things)
   Tracing options:
       MBn or Bounding=bool Bounding_Threshold=integer
              Use automatic bounding slabs if more than n objects are
in  the
              scene.
       Qn or Quality=integer
              Render  at  quality  n.  Qualities range from 0 for rough
images
              and 9 for complete ray-tracing and textures, and 10 and
11  add
              radiosity.
       A0.n or Antialias=bool Antialias_Threshold=integer
              Do antialiasing on the pixels until the difference between
adja‐
              cent pixels is less that 0.n, or the maximum recursion
depth  is
              reached.
       AMn or Sampling_Method=integer
              Specify  the  method of antialiasing used, non-adaptive (n
= 1),
              or adaptive antialiasing (n = 2).
       Jn.n or Jitter=bool Jitter_Amount=float
              Specify maximum radius,  in  pixels,  that  antialiased
samples
              should be jittered from their true centers.
       Rn or Antialias_Depth=integer
              Set  the  maximum recursion depth for antialiased pixel sub-
sam‐
              pling.
       UA or Output_Alpha=bool
              Use alpha channel for transparency mask.
       UL or Light_Buffer=bool
              Use light buffer to speed up rendering.
       UV or Vista_Buffer=bool
              Use vista buffer to speed up rendering.
HTH.
Jim
Date: 14 Sep 2007 14:31:21
Message: <46ead379@news.povray.org>
Or for more verbose information:
http://povray.org/documentation/view/3.6.1/223/
Section 2.1.2.8.4
Jim
