POV-Ray : Newsgroups : povray.unix : Keeping rendered image window. Server Time
10 Jun 2024 09:43:16 EDT (-0400)
  Keeping rendered image window. (Message 1 to 9 of 9)
Subject: Keeping rendered image window.
Date: 3 Jun 2007 04:50:02
Message: <web.4662800cc163ac55909d55d0@news.povray.org>
I did a little povray programming in Windows a few years ago and I thought I
would re-visit it. I am now running slackware Linux.
I successfully compiled and installed povray and I am am able to render
images. I edit the file using Kedit and run povray from the command line.
One thing I am finding irritating is that I can see the image being
rendered but as soon as the image is rendered the window closes and the
only way to view the image is to open the saved file with a graphics
program.
Another oddity was when I changed povray.conf this had
; Width of image in pixels.  Accepts integer values.
Width = 320
; Height of image in pixels.  Accepts integer values.
Height = 240
When I changed this to 800 and 800 I has a distorted lengthened image. So I
have chaned it to 640 480 and the image looks Ok but I am puzzled that
width and length cannot be varied independently.
TIA
Alan
Subject: Re: Keeping rendered image window.
Date: 3 Jun 2007 04:51:11
Message: <466280ff@news.povray.org>
http://tag.povray.org/povQandT/languageQandT.html#aspectratio
Date: 3 Jun 2007 06:21:33
Message: <4662962d@news.povray.org>
> program.
Try this option in your povrayrc config file:
Pause_When_Done=true
This will keep the display window open even when the render has finished
Joerg
Date: 3 Jun 2007 07:35:01
Message: <web.4662a67ed5db65c2909d55d0@news.povray.org>
Joerg
Thanks. That works fine.
Warp
Thanks. Does that mean that the settings in povray.ini are overridden?
Alan
Date: 3 Jun 2007 11:24:07
Message: <4662dd16@news.povray.org>
  There's no ini setting for aspect ratio. Nothing is overridden anywhere.
Date: 3 Jun 2007 14:40:02
Message: <web.46630a2bd5db65c2909d55d0@news.povray.org>
Don't understand this. Changing the width and height values in povray.ini
does appear to change the ratio of the image.
Date: 3 Jun 2007 14:56:40
Message: <46630ee8$1@news.povray.org>
The .ini just tells the renderer how many pixels to render.
The aspect ratio tells the programm what aspect ratios the "pixels" have.
They are independent from each other.
So changing the height and width doesn't change the aspect ratio ...
that all
>>                                                           - Warp
Date: 3 Jun 2007 15:12:03
Message: <46631283@news.povray.org>
  But they don't affect the aspect ratio of the camera.
Date: 3 Jun 2007 18:45:27
Message: <46634487$1@news.povray.org>
>> program.
> Joerg
Also the +P command-line option will do it.
      -=- Larry -=-
PS.  FWIW, I frequently use a bash script I wrote.  It's not
particularly versatile, but it's convenient when only a small set of
"standard" options are adequate.  I use +P as one of these standards.
It also has a fixed set of common sizes that are selected with a single
number.
