![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is rather annoying.
Why would POVRay go looking for a Windows 3.1 style ini file or some .conf
file when all parameters are specified on the command line ? Simply to
determine the rights and permissions for output ?
$ povray -I
/export/home/dclarke/build/povray/renders/glassworks/glassworks.pov -L
/opt/csw/share/povray-3.6/include -W 640 -H 480 -P -V -X 640 -D -SP 8 -B
512 -FN16 -O
/export/home/dclarke/build/povray/renders/glassworks/g_640x480_001.png -Q9
-A0.3 -AM2 -J0.0 -R3 -K0.3141 -KC -GA
povray: cannot open the user configuration file
/export/home/dclarke/.povray/3.6/povray.conf: No such file or directory
Could not find file '640.ini'
Cannot open INI file '640'.
Cannot process command-line due to a parse error.
This is not a valid command-line. Check the command-line for syntax errors,
correct them, and try again!
Valid command-line switches are explained in detail in the reference part of
the documentation.
To get a short list of command-line switches, use either the '-h', '-?',
'-help' or '--help' switch.
Failed to render file due to error(s)!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: command line fails due to missing ini file ?
Date: 17 Dec 2006 18:38:15
Message: <4585d4e7$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> $ povray -I
> 512 -FN16 -O
You put spaces between some options and their respective values
(here: -I, -L, -W, -H, -X, -SP, -B, -O) while there should be none.
Please read again the docs. Also I recommend checking the meaning
of using either a - or + to introduce a command-line option.
- NC
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> - NC
sure enough .. I went back and took a long hard look at that.
I was able to get all the features that I wanted and then started over by
tossing this into a fixed class priority process :
bash-3.1$ /bin/priocntl -e -c FX -m 0 -p 0 ptime povray
-I/export/home/dclarke/build/povray/renders/glassworks/glassworks.pov
-L/opt/csw/share/povray-3.6/include -W1024 -H768 -X1024 -B512 -Q9 -AM2
-A0.3 -P -V -SP4
-O/export/home/dclarke/build/povray/renders/glassworks/g_1024x768_001.png
Persistence of Vision(tm) Ray Tracer Version 3.6.1 (CC @
sparc-sun-solaris2.8)
it seems to be running fine now :-)
Dennis
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
