![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I see:
installing KDE integration for user 'greg'...
copying POV-Ray icons...
generating POV-Ray file types...
installing main POV-Ray 3.6 submenu...
installing ini file link...
installing configuration file link...
installing documentation link...
installing sample scene render links...
modifying povray.conf...
checking conf file /home/greg/.povray/3.6/povray. conf
cp: cannot stat `/usr/local/etc/povray.conf': No su ch file or directory
Error: could not modify povray.conf
Finished installing KDE panel entries
whereas the directory structure is
/usr/local/etc/povray/3.6/povray.conf
Is the KDE installer looking for the file to change in the wrong
subdirectory?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> subdirectory?
No, this can only happen if there is no io-restrictions configuration
file found at all which is only the case if you started the KDE install
without previously installing POV-Ray. It should of course also check
this before but it is difficult to check every possible misuse of the
script. ;-)
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No, I installed povray exactly as per the instructions online.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I was about to say this can't be but there is indeed a small error in
the script that causes a malfunction here.
Do an 'install user' before 'install kde' and you should be fine.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
