![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am trying to compile Povray on Debian AMD64, but with no succsess
it ends with the following message:
povms.cpp: In function `int POVMSUtil_TempAlloc(void**, int)':
povms.cpp:3830: error: unerkennbares insn:
(insn:HI 82 81 64 2 0x2a9682e780 (set (reg:SI 58)
(plus:SI (mult:SI (reg:SI 58)
(const_int 2 [0x2]))
(const_int -2 [0xfffffffffffffffe]))) -1 (insn_list 81 (nil))
(nil))
povms.cpp:3830: internal compiler error: in extract_insn, at recog.c:2175
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://gcc.gnu.org/bugs.html> for instructions.
For Debian GNU/Linux specific bug reporting instructions, see
<URL:file:///usr/share/doc/gcc-3.3/README.Bugs>.
make[3]: *** [povms.o] Fehler 1
make[2]: *** [all-recursive] Fehler 1
make[1]: *** [all-recursive] Fehler 1
make: *** [all] Fehler 2
has anyone compiled povray under Debian AMD64 Debian and can help me?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> (nil))
This is a problem with GCC, not POV-Ray. I have faced it myself
(though when compiling the Zlib included in the POV-Ray distro) trying
to compile with gcc-3.3.4. According to GCC bugzilla*, this internal
compiler error (aka ICE) seems to occur in the 3.3 series on the AMD64,
at least this 3.3.4 release.
OTOH, POV-Ray compiles fine with the GCC 3.4.x series. Moreover
the later supports the k8/opteron compiler flags, which should result in
a faster POV-Ray binary (also the 3.3.x series usually produce slightly
slower code on other platforms). I recommand you install GCC 3.4.1 (or
the newest 3.4.2) and try again compiling POV-Ray with it -- works for me.
- NC
(*) http://gcc.gnu.org/bugzilla/show_bug.cgi?id=16874
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Why don't you do as the compiler tells you?
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
