POV-Ray : Newsgroups : povray.unix : execute povray thru cgi Server Time
21 Apr 2025 17:45:12 EDT (-0400)
  execute povray thru cgi (Message 1 to 4 of 4)
Subject: execute povray thru cgi
Date: 4 Nov 2003 18:25:01
Message: <web.3fa83455c2fac20618d771c60@news.povray.org>
I want to execute povray from php. But it does not work. No error
There is wrote about execution povray from cgi , but i cant see right
answer.
So i get up this question again.
I leav php and write test script for perl. Problem are the same
This sctipt that i have to test.
###test.pl
#!/usr/bin/perl
print "Content-type: text/plain\n\n";
system("/usr/local/bin/povray +O/tmp/monica.tpl.png +I/tmp/monica.pov.tpl
/tmp/mypov.ini 2>&1 ");
print is done
This is ini file
###mypov.ini
Width = 800
Height = 600
Bounding_Threshold = 3
Display=off
Verbose=off
Library_Path=/usr/local/share/povray-3.5
Library_Path=/usr/local/share/povray-3.5/include
Library_Path=/home/httpd/cgi-bin/fonts
Library_Path=/mnt/share/000/Development/www/stereogram_web/gallery/depthmaps
Output_to_File=false
Output_File_Type=N8             ;; (+/-Ftype)
RESULT  in shell: about 30 sec
povray output ....
is done.
RESULT in cgi: less then 1 sec
is done
QUestuion: it seems to me povray process does not execute. why? What do i
wrong?
NEXT EXPEREMENT
Edit test script  and delete left povray without arguments.It shows povray
information.
#####test.pl
#!/usr/bin/perl
system("/usr/local/bin/povray  2>&1 ");
print is done
RESULT it works well in shell and in cgi
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins.
is done
This is strange for me. May be i dont understand something ??????
Help me . Thanx.
PAUL
Subject: Re: execute povray thru cgi
Date: 4 Nov 2003 20:28:55
Message: <3fa85257@news.povray.org>
> wrong?
  IIRC there's a bug in unix.cpp which causes POV-Ray to crash when
there's no tty. The fix was simple, but I don't remember what was it
(but you needed to fix unix.cpp and recompile).
  The next version will fix this problem, among other things.
Date: 5 Nov 2003 09:51:21
Message: <3fa90e69@news.povray.org>
In article <3fa85257@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
If you read to the end you will notice this most likely isn't the problem as
he gets output.
I would recommend to make sure display is disabled, aka -d on the
command-line is passed as the last thing.
    Thorsten
e-mail: tho### [at] trfde
Date: 5 Nov 2003 12:20:01
Message: <web.3fa9311aa7eb47ca91325a70@news.povray.org>
I v solved this problem. Just recompile povray --without-x and execute with
-d oprion.
Thanx for care
Paul Khimyack
