POV-Ray : Newsgroups : povray.unix : Error building POV-Ray 3.7 on Linux (Debian Testing) Server Time
1 Jun 2024 15:17:44 EDT (-0400)
  Error building POV-Ray 3.7 on Linux (Debian Testing) (Message 1 to 10 of 15)
Subject: Error building POV-Ray 3.7 on Linux (Debian Testing)
Date: 21 Nov 2013 07:15:00
Message: <slrnl8rua3.ipl.bisqwit@bisqwit.iki.fi>
I am having trouble building POV-Ray 3.7.
I downloaded povray-3.7-stable.zip from the github page at
  https://github.com/POV-Ray/povray/tree/3.7-stable
and unzipped it.
I also installed the debian package "libboost-all-dev", which
installs every Boost library. The current version is 1.54.0.
I applied a preliminary fix. (Explained below.)*
In the unix/ directory, I ran prebuild.sh.
It lists the following errors and warnings:
+ aclocal -I .
  configure.ac:302: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
  ../../lib/autoconf/lang.m4:193: AC_LANG_CONFTEST is expanded from...
  ../../lib/autoconf/general.m4:2590: _AC_COMPILE_IFELSE is expanded from...
  ../../lib/autoconf/general.m4:2606: AC_COMPILE_IFELSE is expanded from...
  ../../lib/m4sugar/m4sh.m4:639: AS_IF is expanded from...
  ../../lib/autoconf/general.m4:2031: AC_CACHE_VAL is expanded from...
  ../../lib/autoconf/general.m4:2052: AC_CACHE_CHECK is expanded from...
  unix/config/ax_boost_thread.m4:32: AX_BOOST_THREAD is expanded from...
  configure.ac:302: the top level
+ autoheader --warnings=all
  (repeats the same warnings as above)
+ automake --warnings=all
  configure.ac:185: error: required file 'unix/config/compile' not found
  configure.ac:185:   'automake --add-missing' can install 'compile'
  source/Makefile.am:35: warning: source file 'frontend/shelloutprocessing.cpp' is in
a subdirectory,
  source/Makefile.am:35: but option 'subdir-objects' is disabled
  automake: warning: possible forward-incompatibility.
  automake: At least a source file is in a subdirectory, but the 'subdir-objects'
  automake: automake option hasn't been enabled.  For now, the corresponding output
  automake: object file(s) will be placed in the top-level directory.  However,
  automake: this behaviour will change in future Automake versions: they will
  automake: unconditionally cause object files to be placed in the same subdirectory
  automake: of the corresponding sources.
  automake: You are advised to start using 'subdir-objects' option throughout your
  automake: project, to avoid future incompatibilities.
  source/Makefile.am:35: warning: source file 'frontend/rendermessagehandler.cpp' is
in a subdirectory,
  source/Makefile.am:35: warning: source file 'frontend/console.cpp' is in a
subdirectory,
  (and so on repeated for a few dozen cpp files)
  /usr/share/automake-1.14/am/library.am: warning: 'libpovray.a': linking libraries
using a non-POSIX
  /usr/share/automake-1.14/am/library.am: archiver requires 'AM_PROG_AR' in
'configure.ac'
  source/Makefile.am:32:   while processing library 'libpovray.a'
  vfe/Makefile.am:35: warning: source file 'unix/vfeplatform.cpp' is in a
subdirectory,
  vfe/Makefile.am:35: but option 'subdir-objects' is disabled
  vfe/Makefile.am:35: warning: source file 'unix/unixoptions.cpp' is in a
subdirectory,
  vfe/Makefile.am:35: warning: source file 'unix/unixconsole.cpp' is in a
subdirectory,
  vfe/Makefile.am:35: warning: source file 'unix/platformbase.cpp' is in a
subdirectory,
  /usr/share/automake-1.14/am/library.am: warning: 'libvfe.a': linking libraries using
a non-POSIX
'configure.ac'
  vfe/Makefile.am:32:   while processing library 'libvfe.a'
+ autoconf --warnings=all
  configure.ac:295: warning: The macro `AC_LANG_SAVE' is obsolete.
  configure.ac:295: You should run autoupdate.
  ../../lib/autoconf/lang.m4:125: AC_LANG_SAVE is expanded from...
  unix/config/acx_pthread.m4:78: ACX_PTHREAD is expanded from...
  configure.ac:295: the top level
  configure.ac:295: warning: The macro `AC_LANG_C' is obsolete.
  ../../lib/autoconf/c.m4:72: AC_LANG_C is expanded from...
  configure.ac:295: warning: The macro `AC_TRY_LINK' is obsolete.
  ../../lib/autoconf/general.m4:2687: AC_TRY_LINK is expanded from...
  configure.ac:295: warning: The macro `AC_LANG_RESTORE' is obsolete.
  ../../lib/autoconf/lang.m4:134: AC_LANG_RESTORE is expanded from...
  + cat ./configure
  + sed -e 's,configure.gnu  --help=recursive,& --srcdir=$ac_srcdir,g' -e 's,\(cd
\)\($ac_\)\(pop\)*\(dir\),\1"\2\3\4",g' -e
's,$am_aux_dir/missing,\\"$am_aux_dir\\"/missing,g'
  + mv -f ./configure.tmp ./configure
  + chmod +x ./configure
  + rm -f -r ./autom4te.cache
  sed: can't read ./Makefile.in: No such file or directory
It generates a "configure" script in "unix/.." .
Then I do:  cd ..; ./configure COMPILED_BY="Bisqwit <bis### [at] ikifi>".
configuring stops at the following error:
  checking that generated files are newer than configure... done
  configure: creating ./config.status
  config.status: error: cannot find input file: `Makefile.in'
Bash's autocomplete gives me the following list of versions of autotools:
  unix$ automake
  automake       automake-1.14  automake-1.4   automake-1.8   automake-1.9
  unix$ autoconf
  autoconf      autoconf2.13  autoconf2.50  autoconf2.59  autoconf2.64
  unix$ autohead
  autoheader      autoheader2.13  autoheader2.50  autoheader2.59  autoheader2.64
  unix$ acloc
  aclocal       aclocal-1.14  aclocal-1.4   aclocal-1.8   aclocal-1.9
  autoconf version is 2.69. automake version is 1.14.
  autoheader version is 2.69. aclocal version is 1.14.
What should I do?
*) Preliminary fix:
In unix/config/ax_boost_thread.m4, I added -lboost_system
right next to -l$ax_lib, because otherwise configure would
complain that it cannot link with boost_thread and config.log
would indicate this linker error message:
undefined reference to symbol '_ZN5boost6system15system_categoryEv'
Joel Yliluoma
http://iki.fi/bisqwit/
Subject: Re: Error building POV-Ray 3.7 on Linux (Debian Testing)
Date: 21 Nov 2013 07:39:37
Message: <528dff09$1@news.povray.org>
Am 21.11.2013 13:15, schrieb Joel Yliluoma:
Am I correctly infering from the subject line that you are running a
non-stable version of Linux?
It seems to me that the autoconf tool suite has some backward
compatibility issues. Which, if I may say so, is /not/ the best thing
that can happen with a tool that was designed to /solve/ compatibility
issues...
Folks, did anybody already try compiling POV-Ray 3.7 on the latest
stable Debian?
Date: 21 Nov 2013 07:46:15
Message: <528e0097$1@news.povray.org>
> issues...
indeed those warnings are part of the landscape but shouldn't stop
things (as the user indicated) ... look further down in the original
post and see the missing Makefile.in problem that I was having .... I
think user should pull again using git (unless your updates flowed into
the zip download)
Date: 21 Nov 2013 07:56:03
Message: <528e02e3$1@news.povray.org>
>> issues...
> the zip download)
LOL ... knew it was going to happen eventually. I think the colour.ccp
issue needs to flow to the /povray/ github as well
Date: 21 Nov 2013 08:42:59
Message: <528e0de3$1@news.povray.org>
Am 21.11.2013 13:56, schrieb James Holsenback:
>>> issues...
>> the zip download)
Nope - the missing Makefile.in is just an indication that /something/
tore up the generation of said file. The duplicate file thing generates
a particular message much earlier, which isn't there in this case, so
something else must be going wrong.
Besides, the povray github doesn't even have the duplicate files yet.
Date: 21 Nov 2013 10:08:01
Message: <528e21d1$1@news.povray.org>
On 11/21/2013 07:15 AM, Joel Yliluoma wrote:
In the +automake section this is where things start to differ from what
I'm getting:
<snipped a bunch>
then I think this is what's causing the rest of the problems:
in a subdirectory,
subdirectory
subdirectory,
using a non-POSIX
'configure.ac'
subdirectory,
subdirectory,
subdirectory,
subdirectory,
using a non-POSIX
'configure.ac'
<snipped some more>
because of the above fail ... I'm thinking there needs to be some kind
of error detection here that makes an aborted sequence apparent
>    unix$ automake
>    unix$ autoconf
>    unix$ autohead
>    unix$ acloc
for what it's worth I'm using:
automake (GNU automake) 1.11.1
autoconf (GNU Autoconf) 2.68
autoheader (GNU Autoconf) 2.68
aclocal (GNU automake) 1.11.1
Date: 21 Nov 2013 11:51:44
Message: <528e3a20$1@news.povray.org>
one other thing that /might/ cause problems ... the version of make you
are using. INSTALL file cites version 3.79 or above. on mine:
make --version
returns GNU Make 3.82
Date: 21 Nov 2013 15:00:01
Message: <web.528e6598ec21ff0aae7e3a340@news.povray.org>
Have you tried the solutions from the thread named "Packaging povray 3.7 stable
for Arch Linux"? The errors look somewhat similar to me.
Best regards,
Date: 21 Nov 2013 15:23:49
Message: <528e6bd5$1@news.povray.org>
Am 21.11.2013 20:57, schrieb xyproto:
> Best regards,
Indeed. Looks like we should consider those as permanent changes to the
Unix build stuff; but we'll need to check when that option was first
supported by automake.
Date: 22 Nov 2013 14:03:20
Message: <slrnl8vajo.hjo.bisqwit@bisqwit.iki.fi>
It's stable all right. What it isn't is stale.
Joel Yliluoma
