POV-Ray : Newsgroups : povray.unix : povray 3.6.1 and Mac OS-X Server Time
19 Apr 2025 07:02:27 EDT (-0400)
  povray 3.6.1 and Mac OS-X (Message 1 to 10 of 13)
Subject: povray 3.6.1 and Mac OS-X
Date: 27 Nov 2004 05:30:21
Message: <pdb_NOSPAM-412895.21302327112004@news.povray.org>
There has been some discussion here about PovRay 3.6.1
compiling under Mac OS-X. I can confirm that it does
compile "out-of-the-box", I just did it as a test. So,
if it doesn't for you then I imagine you don't have the
full developer tools installed. If anyone does does want
the command line version for Mac OS-X then let me know
and I'll make a binary available.
Paul Bourke
pdb_NOSPAMswin.edu.au
Subject: Re: povray 3.6.1 and Mac OS-X
Date: 5 Dec 2004 22:50:00
Message: <web.41b3d63edf8ab43170217cea0@news.povray.org>
Hi Paul,
I am interested in how you were able to successfully compile the command
line version.  I have tried several times on two different machines.
On both of my machines (both G4s) it seems to go through the process just
fine and once even completed the "make check" but when it is finished  with
the "make install" I still get a message whenever I type the povray command
that says:
tcsh: povray: Command not found.
I am running OS X 10.3.6 with Xcode 1.5 including the November GCC 3.3
updater.  Whenever I enter the "make check" command I get an error message:
Scene File Parser Initialization Error: Reading from
'/povray-3.6.1/scenes/advan
ced/biscuit.pov' is not permitted.  Check the configuration in
 '/usr/local/etc/povray/3.6/povray.conf'.
I checked this "povray.conf" file but I don't know what to change and I am
not sure that it is actually the problem.  I also checked the permissions
for the "biscuit.pov" script and found it was set to let anyone read it.  I
have also tried doing everything logged in as root but it doesn't change
the "make check" results.
Anyway,  I appreciate any advice and guidance in this process.
thanks,
Chris
Date: 5 Dec 2004 23:35:00
Message: <web.41b3e0dedf8ab43170217cea0@news.povray.org>
Just to be thorough I did go through the "/var/root/.povray/3.6/povray.conf"
file and changed the lines
[File I/O Security]
;none       ; all read and write operations on files are allowed.
;read-only  ; uses the "read+write" directories for writing (see below).
restricted  ; uses _only_ "read" and "read+write" directories for file I/O.
to
[File I/O Security]
;restricted  ; uses _only_ "read" and "read+write" directories for file I/O.
and
[Shellout Security]
;allowed
forbidden
to
[Shellout Security]
allowed
;forbidden
Still, I got the same error mentioned in my previous posting with the "make
check" command.
thanks again for any help,
Chris
Date: 6 Dec 2004 12:02:48
Message: <41b490b8$1@news.povray.org>
	Try the tcsh command 'rehash' and then 'povray' should be found,
assuming the binary is installed in a directory that belongs to your
PATH environment variable.  Check 'printent PATH' for that.
	The 'make check' command is meant to be run only before the
package is installed with 'make install'.   If you run 'make check'
again afterwards, the default settings in the ~/.povray/3.6/povray.conf
file will prevent you reading the demo scene again.  This behaviour is
expected.  The 'make check' command is there only for verifying that
the binary you just compiled is working normally, before you install
all the rest of the scene, include, and related files.
	- NC
Date: 6 Dec 2004 12:08:47
Message: <41b4921f@news.povray.org>
> to
> [File I/O Security]
> check" command.
	That's odd.
	Please, write the paths where you have installed POV-Ray to.  You just
need to report the content of the /var/root/.povray/3.6/povray.ini file
(the Library_Path entries at the end of the file).
	Also report the full last section of the povray.conf file, i.e.
all read(*) and read-write(*) entries at the end of the file.
	- NC
Date: 6 Dec 2004 12:12:12
Message: <41b492ec@news.povray.org>
	Sorry, that's  'printenv PATH'  or simply  'echo $PATH' .
	Also, if you open a new shell and POV-Ray is installed in a standard
directory, you should immediatly be able to use 'povray' without doing the
'rehash' first.
	- NC
Date: 7 Dec 2004 03:10:00
Message: <web.41b56343df8ab43170217cea0@news.povray.org>
Nicolas,
Thanks so much for your suggestions.  If it's not already obvious, I am only
a beginner with unix so your advice pointed me in the right direction to
fix things.  I'll explain what I discovered in the process in the hopes
that it might be of assistance to other unix neophytes with apple osx
computers. :)
The default target directory for the binary install is /usr/local/bin (plus
other folders as explained in the INSTALL document).
On the other hand, my $PATHs are
/bin:/sbin:/usr/bin:/usr/sbin
I have never changed this and it may be a "default" so this may or may not
end up being an issue for other osx users.  [Would it be possible for the
installer to check the $PATH variable and install the binaries based on the
results?]
Rather than change this pathway I used the instructions in the INSTALL doc
to
% ./configure --prefix=/usr/bin COMPILED_BY="chris morgan
<iso### [at] yahoocom>"
% make check install
This seemed to work better because the check worked except that even after
using "rehash" I still got the message:
So I looked back through the reporting in the terminal window and found the
files were actually installed in usr/bin/etc as well as usr/bin/bin.
So, next (after uninstalling this version) I left of the /bin and installed
it with
% ./configure --prefix=/usr COMPILED_BY="chris morgan <iso### [at] yahoocom>"
and it worked!!!!
Now the only problem remaining is that I didn't note where it installed the
..inc files so in the meantime I just used the "Library_Path=" in my .ini
file to reference the .inc files that were in the installer folder.
thanks again for your help.
chris
Date: 7 Dec 2004 09:31:18
Message: <41b5beb6$1@news.povray.org>
	I don't know what is "standard" in MacOSX, but I'd suggest you to
have a /usr/local/bin in your PATH (before any other) and install all
additional packages, such as POV-Ray, in there.  This has the advantage
to avoid messing up the system.  Moreover I guess this is what is
recommanded by the FHS (filesystem hierarchy standard).
> results?]
	For the reasons above, the answer is "no"  :-)
	In principle you can easily add the /usr/local/bin path in the
default PATH environment, either as root or as non-priviledged user.
In the case of tcsh, you should add  'setenv PATH /usr/local/bin:$PATH'
in either /etc/csh.cshrc or /etc/csh.login (as root) or in ~/.cshrc
~/.login (as user).  Consult the tcsh manual ('man tcsh', in section
"Startup and shutdown") for further details.
	Good  ;-)
	If you have /usr/local/bin in your PATH as discussed above, you
will not need to use the --prefix option for any package that uses the
GNU configure scheme (which nowadays is the de facto standard for source
packages).
	- NC
Date: 7 Dec 2004 13:54:06
Message: <41b5fc4e@news.povray.org>
In article <41b5beb6$1@news.povray.org> , Nicolas Calimet
/Applications for all Mac OS X applications.  Normal users never see the
command-line. Depending on the Mac OS X version and install options used,
the command-line environment isn't setup ... but don't ask for the defaults
if it is setup, I haven't had to do a clean install ever since I got my
system almost three years ago.
    Thorsten
e-mail: tho### [at] trfde
Date: 7 Dec 2004 21:50:00
Message: <web.41b66a6edf8ab43170217cea0@news.povray.org>
Nicolas, thanks again for the pointers.  After you first introduced me to
$PATH I researched it and actually come across the means of appending the
PATH.  However, my thinking at the time was that it wasn't a good idea for
me because I will eventually need to install this command line version on
15 computers in my lab at school.  I figured I could save a step by
avoiding the need to add /usr/local/bin on each machine.   But now I see it
is better to not fight a standard and so I took your advice and did this on
a second machine by just using the vi editor on the /etc/csh.login document
(I hope that is okay).  And even though the "make check" still didn't work,
povray worked flawlessly and I didn't even have to do anything special to
show it where the include files were.
Thorsten is correct that on the MacOSX systems the root account is disabled
by default in order to prevent users from doing things they shouldn't with
the system files.  On the other hand, the primary user has so-called
"adminstrator" priveledes similar to root including 'sudo' (but not 'su' -
yet, another point that might affect a would-be mac-based user wanting to
install the command-line version since the installer step 3 is "su").
Still, perhaps most people fiddling around with the terminal application in
OSX will have enabled the root account (which is very easy to do).
Finally, I just did a quick search online and discovered that beginning with
OSX 10.2 (we are now in version 10.3) /usr/local/bin is "no longer part of
the default environment variables".  So, this issue will probably end up
being a problem for anyone like me who doesn't really know what they are
doing :).  Should the INSTALL document point this out or does this affect
too few people?
thanks again for all of your help.
chris
ps, since I mentioned it, can I impose on you to suggest any UNIX resources
that deal with installing software on multiple machines across a network?
I have heard of 'shell scripts' before and I am wondering if this is the
direction I need to research.
