POV-Ray : Newsgroups : povray.unix : MegaPov on FreeBSD? Server Time
11 Jun 2026 01:38:57 EDT (-0400)
  MegaPov on FreeBSD? (Message 1 to 6 of 6)
Subject: MegaPov on FreeBSD?
Date: 31 Jul 2001 15:36:51
Message: <86bsm0x53x.fsf@chuck.mtnk1.on.home.com>
I've been trying to post this with Pan but it never worked... so I finally got gnus on
xemacs but I don't like the interface.  Anyways...
Has anyone tried compiling MegaPov on FreeBSD?  I've been drooling over the new
features and improvements for a long time ;-p
Subject: Re: MegaPov on FreeBSD?
Date: 31 Jul 2001 18:57:46
Message: <slrn9mea63.4em.steve@zero-pps.localdomain>
>I finally got gnus on xemacs but I don't like the interface.  Anyways...
>I've been drooling over the new features and improvements for a long time ;-p
I got my copy of MegaPov 0.7 from here:
http://perso.enst.fr/~jberger/mpov/mpov.html
I just did make, make install and all was well.  On RH6.2 but it looked fairly
standard, so should work on anything.
 10:46pm  up 18 days, 48 min,  2 users,  load average: 1.07, 1.08, 1.10
Date: 1 Aug 2001 10:10:45
Message: <867kwnx43p.fsf@chuck.mtnk1.on.home.com>
Thanks, I downloaded it last night and the compile went fine.  However, it doesn't
seem to want to process any of the new commands.  Every time I try to render a file it
says that it's "(compatible to 3.1)".  I added the "#version unofficial megapov 0.7;"
to the pov and include file but it still didn't work.  I even downloaded one of the
demo files and tried to render that, but it said it couldn't open the .INI/.DEF file
'sys'.  Any ideas?
Date: 1 Aug 2001 12:10:23
Message: <slrn9mg96i.9c9.steve@zero-pps.localdomain>
>However, it doesn't seem to want to process any of the new commands.  Every
>time I try to render a file it says that it's "(compatible to 3.1)".  I added
the "#version unofficial megapov 0.7;" to the pov and include file
>but it still didn't work.  I even downloaded one of the demo files and tried
>to render that, but it said it couldn't open the .INI/.DEF file 'sys'.  Any
>ideas?
2 possibles, did you go into the "unix" directory to compile?
and is your executable in the same directory as your x-povray executable?
These are just guesses, so may not lead you to the answer to your
problem.
  4:45pm  up 18 days, 18:47,  2 users,  load average: 1.05, 1.04, 1.01
Date: 1 Aug 2001 13:15:38
Message: <864rrrwvjk.fsf@chuck.mtnk1.on.home.com>
Oops, nevermind, it actually does work.  I just forgot the syntax for the command line
arguments in my excitement to try it out ;-)
Subject: test
Date: 1 Aug 2001 21:59:03
Message: <3b68b3e7$1@news.povray.org>
In article <86b### [at] chuckmtnk1onhomecom>, "Chuck"
test in pan
