POV-Ray : Newsgroups : povray.unix : Trying to build on OpenSuse 13.1 Server Time
17 Jun 2026 08:24:18 EDT (-0400)
  Trying to build on OpenSuse 13.1 (Message 1 to 10 of 12)
Subject: Trying to build on OpenSuse 13.1
Date: 26 Sep 2014 08:29:38
Message: <54255c32@news.povray.org>
I recently upgraded top OpenSuse 13.1, and my old build of povray isn't
working anymore (something about a missing .so), so I decided to build
the latest version.
I didn't have autoconf nor automake installed, and prebuild.sh gave
proper messages about them, so I installed them. However, now I'm getting
a lot of messages like:
configure.ac:302: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
/usr/share/automake-1.13/am/library.am: warning: 'libpovray.a': linking libraries
using a non-POSIX
/usr/share/automake-1.13/am/library.am: archiver requires 'AM_PROG_AR' in
'configure.ac'
source/Makefile.am:32:   while processing library 'libpovray.a'
configure.ac:295: warning: The macro `AC_LANG_SAVE' is obsolete.
configure.ac:295: warning: The macro `AC_LANG_C' is obsolete.
configure.ac:295: warning: The macro `AC_TRY_LINK' is obsolete.
configure.ac:295: warning: The macro `AC_LANG_RESTORE' is obsolete.
In the end, no 'configure' script appeared. I don't really know what
causes this.
Subject: Re: Trying to build on OpenSuse 13.1
Date: 26 Sep 2014 08:30:56
Message: <54255c80@news.povray.org>
> causes this.
Correction: It actually did appear, just not in the same directory
as prebuild.sh...
Date: 26 Sep 2014 08:37:14
Message: <54255dfa@news.povray.org>
configure fails with this:
configure:7284: checking for boostlib >= 1.37
configure:7338: g++ -c  -pthread  -I/usr/include conftest.cpp >&5
configure:7338: $? = 0
configure:7340: result: yes
configure:7506: checking whether the Boost::Thread library is available
configure:7538: g++ -c -pthread  -pthread  -I/usr/include conftest.cpp >&5
configure:7538: $? = 0
configure:7553: result: yes
configure:7749: checking whether the boost thread library is usable
configure:7769: g++ -o conftest  -pthread  -pthread -I/usr/include  -L/usr/lib c
onftest.cpp   -pthread  >&5
/tmp/ccQTte5D.o: In function `__static_initialization_and_destruction_0(int, int
conftest.cpp:(.text+0x4f): undefined reference to `boost::system::generic_category()'
conftest.cpp:(.text+0x5b): undefined reference to `boost::system::generic_category()'
conftest.cpp:(.text+0x67): undefined reference to `boost::system::system_category()'
collect2: error: ld returned 1 exit status
Date: 26 Sep 2014 10:12:30
Message: <5425744e@news.povray.org>
Blind reflex with boost: add   LIBS="-lboost_system -lboost_thread" to
the configure line.
And hope that everything-dev of boost is installed.
Just because nobody complains does not mean all parachutes are perfect.
Date: 26 Sep 2014 10:42:54
Message: <54257b6e@news.povray.org>
> the configure line.
Raises the queston why the configure script doesn't do this itself...
Date: 26 Sep 2014 11:55:25
Message: <54258c6d$1@news.povray.org>
>> the configure line.
Well... it worked with old revision of boost... then they broke it (the
linkage is no more done by boost)... it broke around 1.47 or 1.48, IIRC.
Boost have their own motivation (including: to allow someone, despite
the default being to use native thread, to use their own thread... or
its own system for the thread...).
For the configure script of povray: well, lack of manpower, lack of
competence, and it appears past the release date of povray
(when it was tested at that time, boost was still fine).
Povray is now in github, so if you feel to make a patch, well, go for
it: make a fork, make the correction and create the pull request on the
official branch.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 26 Sep 2014 12:52:01
Message: <542599b1$1@news.povray.org>
Am 26.09.2014 14:30, schrieb Warp:
>> causes this.
> as prebuild.sh...
So everything's fine until that point; the warnings are... well, just
warnings, that from a first glance look familiar.
Date: 26 Sep 2014 12:57:39
Message: <54259b03@news.povray.org>
Am 26.09.2014 17:55, schrieb Le_Forgeron:
>>> the configure line.
The nasty thing is that we fixed it (or so I vaguely recall), but looks
like it's come back.
Hm... I think "competence" might be a "false friend" in this context. Dunno.
Date: 26 Sep 2014 14:53:55
Message: <5425b643$1@news.povray.org>
>>>> the configure line.
> Dunno.
You are probably right, it was Friday end-of-day.
You should have repeated the step to help :-)
Date: 26 Sep 2014 16:01:17
Message: <5425c60d$1@news.povray.org>
> the latest version.
> detected in body
> libraries using a non-POSIX /usr/share/automake-1.13/am/library.am:
> archiver requires 'AM_PROG_AR' in 'configure.ac'
> causes this.
# filename install_povray.sh
# install script for Povray 3.7 master
# this script must be run by root
# First we need to install a bunch of libs that make
# life a whole lot easier when using/compiling Povray
zypper in -l -y automake
zypper in -l -y autoconf
zypper in -l -y boost-devel
zypper in -l -y make
zypper in -l -y gcc
zypper in -l -y gcc-c++
zypper in -l -y libjpeg8-devel
zypper in -l -y openexr-devel
zypper in -l -y libpng12-devel
zypper in -l -y libtiff-devel
zypper in -l -y libSDL-devel
zypper in -l -y libSDL2-devel
zypper in -l -y libXpm-devel
zypper in -l -y libXpm-tools
zypper in -l -y libICE-devel
zypper in -l -y libSM-devel
#prepair for unix (linux) compilation
cd /home/ger/Downloads/povray-master/unix/
# and run the prebuild script
./prebuild.sh
# run configure with the appropriate options
./configure COMPILED_BY="Your Name <email.com>" --with-boost-thread=boost_thread-mt
# and now for the heavy lifting part . . .
# Make and install povray
make clean
make install
# all done
HTH
Ger
