POV-Ray : Newsgroups : povray.unix : Further bugs in Makefile Server Time
15 Jul 2025 22:40:39 EDT (-0400)
  Further bugs in Makefile (Message 1 to 7 of 7)
Subject: Further bugs in Makefile
Date: 30 Mar 2014 07:19:58
Message: <5337fdde@news.povray.org>
more problems in 3.7 build process.
After applying the workarounds discussed here I could finish compiling.
 A 'make install' installs a binary into /usr/local/bin, which starts,
but does not really work due to missing files:
% povray
povray: cannot open the system configuration file
/usr/local/etc/povray/3.7/povray.conf: No such file or directory
povray: cannot open the user configuration file
/home/hadmut/.povray/3.7/povray.conf: No such file or directory
povray: I/O restrictions are disabled
make install simply does not install /usr/local/etc/povray/3.7
Instead it tries to install $HOME/.povray into users home directories
and even fails to do so: chown fails since variable povowner is empty.
However:
This is really bad.
A make install should  *never, under no circumstances* fiddle around in
users directories. That's no go.  Things have to be installed under
/usr/local.
regards
Hadmut
Subject: Re: Further bugs in Makefile
Date: 30 Mar 2014 12:35:47
Message: <533847e3$1@news.povray.org>
On 03/30/2014 07:19 AM, Hadmut Danisch wrote:
> Hi,
> % povray
> However:
> This is really bad.
> /usr/local.
> regards
> Hadmut
not 100% sure but what i think maybe going on here is what privileges
were being used during the different steps of the build. generally
speaking elevated privileges are not required until you do make install.
but your case would have required required some juice to do the prebuild
part ... to effect changes in the system area's (sym-links and files). i
think to install the binary and related distribution in non system
area's without privileges you should change that at configure phase.
Date: 31 Mar 2014 04:01:55
Message: <533920f3$1@news.povray.org>
>> Hi,
>> % povray
>> However:
>> This is really bad.
>> /usr/local.
>> regards
>> Hadmut
I believe, but I might be wrong, that the install process of povray (on
unix-like) is currently a bit problematic due to a long inherited history.
Previously, it was a tar-ball for systems ranging from amiga to whatever
commercial-unix (Aix, Hpux and so). It was usually more for personal
usage than collective tools.
When compiling and installing a tar-ball, the culture, nowadays lost, is
to make everything under a lambda user, and then having root run "make
install" once the result of the building process has been checked.
(hence "make check"). Today it turns into "sudo make install"
The issue I currently see with the install process is rather that the
povray binary is expecting local configuration in the user directory
without providing a way to get a template-basic local configuration
files from the binary itself: the user which performs the installation
does get the configuration file, but the 200 other users of the system
do not.
For the unix binary, something like "povray --localconfig" (maybe a
better name for the option would be welcome) should allow the running
user to have its $HOME populated with the relevant .povray/3.7/ subtree
(3.7 being the version of the binary, as usual), basically a copy of the
installed files in /usr/local/etc/povray/3.7 (or whatever INSTALLDIR
instead of /usr/local). BTW, that's probably not the best location (as
recommended by the current version of unified file system, but is the
Linux Filesystem Hierarchy to rules all Unixes ?)
Alternatively, the "povary --localconfig" could be replaced with a shell
script "povray-localinstall" (or similar) which perform the copy,
avoiding a kludge in the main program. Such program would have to be run
by the user when it wants to have its own local configuration files.
/usr/etc (and /usr/local/etc) are reported as being the alternative
place for configuration files, yet virtually unused. (But should povray
dare to add entries in /etc instead ?)
http://www.tldp.org/LDP/Linux-Filesystem-Hierarchy/html/Linux-Filesystem-Hierarchy.html
http://www.linuxtopia.org/online_books/linux_beginner_books/linux_filesystem/usr.html
I suck at naming things, so feel free to provide better names, or even
your opinions.
Just because nobody complains does not mean all parachutes are perfect.
Date: 5 Apr 2014 11:47:56
Message: <534025ac$1@news.povray.org>
Am 31.03.2014 10:01, schrieb Le_Forgeron:
> do not.
Which is odd.
The correct way would be that the installation script does not touch
anyone's home directory and install's things needed under /usr/local/...
A user then might create a local diretory in the home directory, or even
the binary might create the directory structure when run, and file to be
read might be searched in the order $HOME , /usr/local, which is state
of the art.
However, povray is broken in this aspect and should really be fixed.
And maybe reconsider whether it is really necessary to still support the
Amiga, but not properly support Linux.
regards
Hadmut
Date: 9 Apr 2014 12:20:05
Message: <53457335@news.povray.org>
Who said the Amiga is still supported?
Date: 10 Apr 2014 14:22:20
Message: <5346e15c@news.povray.org>
Am 09.04.2014 18:20, schrieb Nicolás Alvarez:
This was meant ironical.
Having make install modify the installer's home directory instead
/usr/local is definitely not Linux level and rather Amiga style.
the unix/prebuild.sh is rather poor in this aspect. It should be
eliminated.
Hadmut
Date: 24 May 2014 19:45:16
Message: <53812f0c$1@news.povray.org>
Am 05.04.2014 17:47, schrieb Hadmut Danisch:
Don't worry, I guess it will be a major hassle to get POV-Ray 3.7 to
compile on an Amiga anyways. For starters, we no longer support any
Amiga build environment.
Actually, the only platform family /really/ well supported is Windows on
the x86 or x64 architecture - which might come as not a big surprise if
you consider that most of the dev team are Windows jockeys, and are not
too familiar with GNU, Posix or even BSD environments & conventions.
Any help in this respect is much appreciated, though pointers to what
needs fixing is only a tiny fraction of the work, and we'd certainly
prefer some hands to actually /do/ the fixing.
