POV-Ray : Newsgroups : povray.unix : Max-gradient warning Server Time
2 Apr 2026 08:38:33 EDT (-0400)
  Max-gradient warning (Message 1 to 4 of 4)
Subject: Max-gradient warning
Date: 29 Jan 2014 20:31:27
Message: <52e9ab6f$1@news.povray.org>
I may be mistaken but has the max_gradient warning disappeared from 3.7?
I ran code from :
news://news.povray.org:119/web.52e8d82bcfb9f6d0a7cafab50@news.povray.org
and got no warning that the max_gradient (at 200) was too high. I then
ran it at max_gradient 20 (too low) and still no warning.
Just for comparison, I also ran under 3.6 and got warnings both times.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Subject: Re: Max-gradient warning
Date: 30 Jan 2014 02:15:00
Message: <web.52e9fb5e24aaf3ae9661f3d80@news.povray.org>
> I ran code from :
> John
> Protect the Earth
We had this discussion some months ago, but I cannot find it actually. IIRC the
solution is to declare the isosurface and then enclose it in an object {}.
Best regards,
Michael
Date: 30 Jan 2014 06:27:14
Message: <52ea3712$1@news.povray.org>
> Best regards,
> Michael
Indeed you did. I missed it then (mainly because I don't follow p.b-t)
but I found it on the web Here:
http://news.povray.org/povray.beta-test/thread/%3C51c55b9f%241%40news.povray.org%3E/?mtop=384497
Declaring the isosurface then enclosing it in a object {} don't seem to
work. Also -WT1 doesn't help.
I guess this is a bug that still needs to be eradicated. Meanwhile, I'll
just carry on developing my landscape isosurfaces with v3.6
John
Protect the Earth
Date: 3 Apr 2014 04:15:01
Message: <web.533d180d24aaf3ae59a9df670@news.povray.org>
> > Best regards,
> > Michael
> John
> Protect the Earth
Hi John,
I just found your message now as I do not follow the unix n.g.
The answer to your question is to "unwrap" your isosurface and use the
isosurface in its "naked" form to get the max_gradient messages.
example:
#if (Naked)
isosurface {....}
#else
#declare Test = isosurface {...}
object {Test}
In its naked version, the messages appear.
