POV-Ray : Newsgroups : povray.unix : Call for test Server Time
19 Mar 2026 03:08:17 EDT (-0400)
  Call for test (Message 1 to 10 of 18)
Subject: Call for test
Date: 4 Jan 2014 17:16:58
Message: <52c8885a$1@news.povray.org>
Hi folks,
can someone using boost >= 1.50 please try building from the following
branch:
https://github.com/POV-Ray/povray/tree/hotfix/boost1.49-boost_system
The build should work /without/ explicitly specifying -lboost_system
when running the configure script.
TIA.
Subject: Re: Call for test
Date: 5 Jan 2014 05:33:38
Message: <52c93502$1@news.povray.org>
Le 04/01/2014 23:16, clipka nous fit lire :
> Hi folks,
> branch:
> TIA.
Well, boost thread library is usable, but it seems to had a fresh
dependency on mkl library. and it was not installed, so configure failed
on that.
Any hint about the package to install to succeed with mkl ?
(on Ubuntu, at least)
Date: 5 Jan 2014 10:03:44
Message: <52c97450$1@news.povray.org>
>> Hi folks,
>> branch:
>> TIA.
> on that.
yep confirmed same problem on the buildbot server (ubuntu/boost 1.53)
dunno ... but following returned:
apt-cache search mkl
mklibs - Shared library reduction script
mklibs-copy - Shared library reduction script
Date: 5 Jan 2014 10:10:42
Message: <52c975f2$1@news.povray.org>
>>> Hi folks,
>>> branch:
>>> TIA.
>> on that.
found another package:
sudo apt-get build-dep revolution-mkl
sudo apt-get install revolution-mkl
yields same results ... the previous packages found /NO/ updates
Date: 5 Jan 2014 17:14:13
Message: <52c9d935$1@news.povray.org>
Am 05.01.2014 16:03, schrieb James Holsenback:
>>> Hi folks,
>>> branch:
>>> TIA.
>> on that.
Did you already do any probing to identify the change responsible?
We did have some mkl-related change recently.
Date: 5 Jan 2014 18:31:58
Message: <52c9eb6e$1@news.povray.org>
>>>> Hi folks,
>>>> branch:
>>>> TIA.
>>> on that.
saw that ... #18 correct?
I added following to my configure run ... LIBS="-lboost_system
-lboost_thread" --without-libmkl
which effectively by-passes the mkl requirement on the buildbot server
I don't understand adding a requirement (mkl) so the gentoo distribution
can build only to require other platform(s) to add --without-libmkl clause
btw: make completed just fine, after configure addition
Date: 5 Jan 2014 19:14:36
Message: <52c9f56c@news.povray.org>
Am 06.01.2014 00:31, schrieb James Holsenback:
>>>> failed
>>>> on that.
I had hoped the author of #18 knew what he was doing, but apparently he
didn't fully. I've thrown the change overboard again now, and
implemented some different changes that I /think/ should be sufficient
to fix the gentoo distro issue.
Learned a lesson today.
Please try again (both master and the hotfix branch).
Please make sure to /not/ use the LIBS="-lboost_system -lboost_thread"
setting for the hotfix branch, as the whole point of that hotfix is to
make configure work reliably without it.
Date: 5 Jan 2014 20:41:58
Message: <52ca09e6$1@news.povray.org>
>>>>> failed
>>>>> on that.
>> clause
both branches (main & hotfix) pass configure (without LIBS="...") here's
what relevant configure output looks like:
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for boostlib >= 1.38... yes
checking whether the Boost::Thread library is available... yes
checking whether the boost thread library is usable... yes
checking for sin in -lmkl... no
checking for sin in -lm... yes
and they both have problems during make starting here (there's more):
../vfe/libvfe.a(vfesession.o): In function
`vfe::vfeSession::Shutdown(bool)':
vfesession.cpp:(.text+0xcd2): undefined reference to
`boost::thread::native_handle()'
vfesession.cpp:(.text+0xce7): undefined reference to
`boost::thread::join_noexcept()'
vfesession.cpp:(.text+0xcfb): undefined reference to
`boost::thread::detach()'
when we get this sorted out, what are the chances of leaving the hotfix
branch for this kind of testing ... I'd like to add it to buildbot
Date: 6 Jan 2014 00:01:03
Message: <52ca388f@news.povray.org>
Am 06.01.2014 02:41, schrieb James Holsenback:
> .../vfe/libvfe.a(vfesession.o): In function
Not much of a surprise for the master, but shouldn't happen with the hotfix.
So here we go for another update...
I named this particular branch "hotfix/boost1.49-boost_system", which
obviously isn't a good name if we want to use it as a general hotfixing
branch ;-)
But I do agree that it's quite a good idea to have buildbot crunch
through all hotfixes we might throw out, so I just renamed the branch to
"hotfix".
Date: 6 Jan 2014 07:57:42
Message: <52caa846@news.povray.org>
> hotfix.
still problem with hotfix ... on the other branch, git pull origin
master shows up to date so I didn't bother trying to build from that branch
> branch ;-)
> "hotfix".
thanks ... sounds generic enough!
