Am 12.12.2012 14:56, schrieb clipka in povray.off-topic:
> So now for task 2 step 1: Try to compile the most recent POV-Ray 3.7
> development version on the Pi. I think I already have all the necessary
> libraries installed, but we'll see...
Downloaded & unpacked the original povray-3.7.0.RC6.tar.gz fresh from
povray.org.
"./compile" is considerably slower than on my x86 Linux machine (maybe
the SD card is a bottleneck?), but seems to be happy with what it finds.
I'm not, as I forgot to specify "--prefix=...", so I had to run it again.
"make check" is a slow crawl, which again I blame on the SD card. What
worries me a bit is that I get repeated assembler warnings like:
{standard input}: Assembler messages:
{standard input}:2148: Warning: swp{b} use is deprecated for this
architecture
I wonder what this means; for the time being I suspect this to be a flaw
in the Raspbian distro, specifically the compiler suite.
Anyway, this is going to take ages, so unless this first build already
turns out to run like a charm, the next task is probably to hook up some
external HD via USB and see if that speeds things up. Maybe even a USB
stick will do.
> povray.org.
> architecture
> stick will do.
must be like having christmas come a few weeks early ( a new toy to play
with) ... have fun
Am 12.12.2012 15:44, schrieb clipka:
... and what /annoys/ me a bit in this context is that each of POV-Ray's
source files is apparently compiled twice in the process. (I thought I
had seen this already on my x86 Linux machine, but never was sure about it.)
Compilation appears to have been successful, the "make check" test
render reported no problems. Now for some rendering with file output...
Am 12.12.2012 20:11, schrieb clipka:
biscuit.pov does exhibit artifacts on the Pi (see povray.beta-test), so
all is not well.
