POV-Ray : Newsgroups : povray.unix : Mosaic Preview Server Time
15 Mar 2026 00:52:02 EDT (-0400)
  Mosaic Preview (Message 1 to 8 of 8)
Subject: Mosaic Preview
Date: 21 May 2010 09:26:24
Message: <4bf68a00$1@news.povray.org>
Greetings,
I think there might be some kind of problem ... here's my observations:
I'm rendering a scene (no radiosity) using these command line options:
+sp64 +ep16 +bs16
I'd expect to get several course looking passes before the final render,
instead I get a solid colored display that blinks several times (the
number of times I'd expect with the sp/ep settings I'm using) then a
final pass with the expected behavior (smaller blocks being rendered
because I'm using +bs16 rather than the default of +bs32)
While I'm on the subject ... radiosity pretrace uses mosaic preview to
display the results of the pretrace steps right? I see this same
behavior (the solid colored display blinking, but it changes color with
each pass) before the final pass is rendered.
I WAS running a customized beta37a compiled on openSUSE 11.2 and decided
to give the last officially released linux  (beta 35a) a try to see if
it was something I did, so I uninstalled my beta37a and built 35a (after
extending the expire) and still see the same behavior.
Can anyone else confirm this?
Cheers Jim
Subject: Re: Mosaic Preview
Date: 21 May 2010 10:26:52
Message: <4bf6982c$1@news.povray.org>
Am 21.05.2010 15:28, schrieb Jim Holsenback:
> +sp64 +ep16 +bs16
I think I can confirm from the Unix source code, which looks somewhat
fishy and would indeed fit that bill if I understand it right.
The implementation of UnixSDLDisplay::DrawFilledRectangle() in
disp_sdl.cpp, which should draw a single-colored rectangle in the
preview window, looks corrupted to me:
- It trims the coordinates to fit inside the image rectangle, which is ok.
- It scales the coordinates to screen coordinates if necessary, which
looks ok as well.
- It calls the function UnixSDLDisplay::UpdateCoord(), which seems to
keep track of a (single) display region that needs to be re-painted.
There seems to be nothing wrong here either.
- It apparently converts the pixel color to the format expected by Unix,
which looks trivial.
- It fills the *entire* rectangle marked for update with the converted
colour, which seems utterly wrong to me.
- It seems to restart a delay timer to prevent all-too-frequent
re-painting of the display.
Can you please try changing the code as follows: Replace the line in
unix/disp_sdl.cpp, function UnixSDLDisplay::DrawFilledRectangle()
(somewhere around line 513) reading:
     SDL_FillRect(m_display, &m_update_rect, sdl_col);
with the following code:
     SDL_Rect tempRect;
     tempRect.x = ix1;
     tempRect.y = iy1;
     tempRect.w = ix2 - ix1; // might need an additional +1
     tempRect.h = iy2 - iy1; // might need an additional +1
     SDL_FillRect(m_display, &tempRect, sdl_col);
I /think/ that should fix it. Feedback would be very much appreciated
(please also feel invited to file a bug report).
Date: 21 May 2010 10:36:12
Message: <4bf69a5c$1@news.povray.org>
Am 21.05.2010 16:26, schrieb clipka:
(Hm, no - that's not what it does; the last step actually causes
re-painting of the display to happen ASAP.)
Date: 21 May 2010 10:40:31
Message: <4bf69b5f$1@news.povray.org>
Looks like the issue would typically only manifest with fast-rendering
images...?
Date: 21 May 2010 14:16:55
Message: <4bf6ce17@news.povray.org>
> images...?
don't think so (could be wrong) ... I recall an image (previous) that
had a rather lengthy pretrace phase and just shrugged it off until I
started playing with something I was trying to understand before adding
it to the docs.
Date: 21 May 2010 14:44:28
Message: <4bf6d48c@news.povray.org>
nailed it :-) way to go!
yes .. i'll follow up
Date: 21 May 2010 16:07:06
Message: <4bf6e7ea$1@news.povray.org>
Am 21.05.2010 20:46, schrieb Jim Holsenback:
Glad to hear that; was there any need to modify the code in any way, or
did it compile exactly as posted? (Unfortunately I can't test the code
myself; I haven't yet managed to get SDL support running for my Linux
compiles.)
Date: 21 May 2010 16:13:44
Message: <4bf6e978$1@news.povray.org>
> compiles.)
cut & paste ... no changes
Thanks!
