POV-Ray : Newsgroups : povray.unix : Problem compiling with X support on Fedora 9 x86_64 Server Time
23 Dec 2024 14:44:12 EST (-0500)
  Problem compiling with X support on Fedora 9 x86_64 (Message 1 to 3 of 3)
Subject: Problem compiling with X support on Fedora 9 x86_64
Date: 16 Sep 2008 06:24:15
Message: <48cf894f$1@news.povray.org>
I am running the configure script for povray 3.61 with the following:
./configure COMPILED_BY="Dave Downing" --x-libraries=/usr/lib64/
LDFLAGS="-L/usr/lib64/"
Have also tried a few variations on that.
Resulting output in part:
checking for X... no
configure: X Window display will be disabled
I have /usr/lib64/libX11.so so that should not be the issue. Also libX11-
devel-1.1.4-1.fc9(x86_64) is installed.
After running make the resulting binary gives me good images, but I would
like to see the X display while they are rendered.
Any ideas what I am missing?
System:
AMD 64 X2 Dual Core 5000+
Fedora 9 x86_64
2 GB Ram
Dave Downing,  Somerset U.K.
No bytes were harmed in the making of this message.
Subject: Re: Problem compiling with X support on Fedora 9 x86_64
Date: 16 Sep 2008 07:38:24
Message: <48cf9ab0$1@news.povray.org>
	Check the config.log file, i.e. search for the "checking for X" string
and look for the next few lines below it.  Hopefully you'll get an idea of
what is wrong.
	- NC
Subject: SOLVED: Re: Problem compiling with X support on Fedora 9 x86_64
Date: 16 Sep 2008 08:13:54
Message: <48cfa302$1@news.povray.org>
string
> of what is wrong.
> 	- NC
Thanks Nicolas,
Your pointer got me sorted. The relevant bit was:
configure:8569: checking for X
configure:8675: g++ -E  conftest.cc
configure:8707:27: error: X11/Intrinsic.h: No such file or directory
A quick Google for Intrinsic.h gave me postings from several people
having the same problem with Fedora not having that file and not sure
which package provides it. The answer for the benefit of others with the
problem is to install libXt-devel.
Thanks again.
