![](/i/fill.gif) |
Hi all!
Emacs 22 no longer works with pov-mode-2.10
http://www.acc.umu.se/~woormie/povray/pov-mode.2.10.tgz
I've made a workaround adding the missing variable. Then I made a simple script for
setting 2 vars that emacs 22 can't digest.
This is the patch (beware of word wrapping!!)
=============CUT HERE======================================
--- pov-mode.el-orig 2008-02-05 19:47:26.000000000 +0100
+++ pov-mode.el 2008-02-05 20:48:46.000000000 +0100
@@ -3,10 +3,15 @@
;; Author: Peter Boettcher <pwb### [at] andrew cmu edu>
;; Maintainer: Peter Toneby <woo### [at] acc umu se>
;; Created: 04 March 1994
-;; Modified: 08 Sep 2003
-;; Version: 2.10
+;; Modified: 05 Feb 2008
+;; Version: 2.10-pl1
;; Keywords: pov, povray
+;; Modified by: Marco Pessotto <mar### [at] gmail com>
+;; 1/5/2008
+;; Workaround for Emacs 22
+;; Peter Tobeby no more maintains pov-mode :-(
;; LCD Archive Entry:
;; povray|Peter Toneby|woo### [at] acc umu se|
;; Major mode for Povray scene files|
@@ -58,7 +63,9 @@
;; To learn about the basics, just load a pov-file and press C-h m.
-;; Modified by: Peter Boettcher <pwb### [at] andrew cmu edu>
+;;Modified by: Peter Boettcher <pwb### [at] andrew cmu edu>
;; 5/8/97:
;; Added font-lock support for Emacs/XEmacs 19
;; Indent under `#declare Object=' lines
@@ -235,9 +242,18 @@
(not font-pov-is-XEmacs20)
(not font-pov-is-XEmacs21)
(= 21 emacs-major-version)))
+(defvar font-pov-is-Emacs22
+ (and (not font-pov-is-XEmacs19)
+ (not font-pov-is-XEmacs20)
+ (not font-pov-is-XEmacs21)
+ (= 22 emacs-major-version)))
- (or font-pov-is-Emacs19 font-pov-is-Emacs20 font-pov-is-Emacs21))
+ (or font-pov-is-Emacs19
+ font-pov-is-Emacs20
+ font-pov-is-Emacs21
+ font-pov-is-Emacs22))
(require 'cl)
(require 'font-lock) ;;[TODO] Not nice to reqire it, the user should
@@ -312,7 +328,7 @@
(customize-set-value 'max-lisp-eval-depth 1000))
;; Yup XEmacs didn't get cutomizations until 20.2.
-(cond ((or font-pov-is-XEmacs20-2 (or font-pov-is-Emacs20 font-pov-is-Emacs21))
+(cond ((or font-pov-is-XEmacs20-2 (or font-pov-is-Emacs20 font-pov-is-Emacs21
(defgroup pov nil
"*Major mode for editing povray 3.X scence files <http://www.povray.org>."
:group 'languages)
@@ -400,12 +416,12 @@
"the commands to run")
- (defcustom pov-home-dir "/usr/local/lib/povray31/"
+ (defcustom pov-home-dir "SHARELIBSPOVRAY"
"*The directory in which the povray files reside."
:type 'directory
:group 'pov)
- (defcustom pov-include-dir "/usr/local/lib/povray31/include/"
+ (defcustom pov-include-dir "SHARELIBSPOVRAY/include"
"*The directory in which the povray includefiles reside."
:type 'directory
:group 'pov)
@@ -422,12 +438,12 @@
:group 'pov)
(defcustom pov-fontify-insanely t
- "*Non-nil means colorize every povray keyword. This may take a while on lare
files. Maybe disable this on slow systems."
+ "*Non-nil means colorize every povray keyword. This may take a while on large
:type 'boolean
:group 'pov)
(defcustom pov-imenu-in-menu t
- "*Non-nil means have #locals and #declares in a menu called PoV in the
menubar. This may take a while on lare files. Maybe disable this on slow systems."
+ "*Non-nil means have #locals and #declares in a menu called PoV in the
menubar. This may take a while on large files. Maybe disable this on slow systems."
:type 'boolean
:group 'pov)
;; CH
@@ -510,10 +526,15 @@
; Find where the menubar icons are placed, should be where pov-mode is...
-(setq pov-icons-location
- (file-name-directory (locate-data-file "povrender.xpm"
- (cons (file-name-directory
(locate-library "pov-mode"))
- (if font-pov-is-Emacs
data-directory data-directory-list)))))
+;; (setq pov-icons-location
+;; (file-name-directory (locate-data-file "povrender.xpm"
+;; (cons (file-name-directory
+;; (if font-pov-is-Emacs
+;;FIX ME
+(setq pov-icons-location "EMACSLISPLIBRARY/povrender.xpm")
;; Lets play with the Toolbar, we want to add buttons for
;; rendering and showing images, lets place them on the rightmost
@@ -597,7 +618,7 @@
(defun font-pov-setup ()
"Setup this buffer for PoV font-lock."
(cond
- ((or font-pov-is-Emacs20 font-pov-is-Emacs21)
+ ((or font-pov-is-Emacs20 font-pov-is-Emacs21 font-pov-is-Emacs22)
;; Tell Font Lock about the support.
(make-local-variable 'font-lock-defaults))
((or font-pov-is-XEmacs19 font-pov-is-XEmacs20)
@@ -619,7 +640,7 @@
(make-local-variable 'font-lock-defaults))))
(cond
- ((or font-pov-is-Emacs20 font-pov-is-XEmacs20-2 font-pov-is-Emacs21)
+ ((or font-pov-is-Emacs20 font-pov-is-XEmacs20-2 font-pov-is-Emacs21
(defface font-pov-object-face
'((((class grayscale) (background light)) (:foreground "DimGray" :bold t))
(((class grayscale) (background dark)) (:foreground "LightGray" :bold t))
@@ -2013,12 +2034,12 @@
;; Let's try to find where the InsertMenu is located...
-(setq pov-insertmenu-location
- (locate-data-directory "InsertMenu" (cons (file-name-directory
- (locate-library "pov-mode"))
- data-directory
- data-directory-list))))
+(setq pov-insertmenu-location "EMACSLISPLIBRARY/InsertMenu")
+;; (locate-data-directory "InsertMenu" (cons (file-name-directory
+;; (locate-library "pov-mode"))
+;; data-directory
+;; data-directory-list))))
(defun pov-im-get-submenunames ()
(interactive)
===================CUT HERE================================================
Untar pov-mode-2.10.tar.gz in your load-path, paste the patch in a file
named e.g. ``Patch'' in the same directory of pov-mode.el,
then:
patch --verbose < Patch
and should be OK.
Then run this simple script, in the same directory too:
#!/bin/bash
# Copyright (C) 2008 Marco Pessotto
# <mar### [at] gmail com>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 3, or (at your option)
# any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# check if povray is in your path
which povray 1>/dev/null 2>/dev/null
if [ ! $? -eq 0 ]; then
echo "povray is not in your PATH. Why?"
exit 1
fi
# I assume the share directory is here
povshare=$(echo $(dirname $(which povray)) | sed -e "s|bin|share/povray-3.6|")
echo "Where is the share directory of povray? "
echo -n "Should be $povshare >>> "
read povshare
if [ "$povshare" == "" ]; then
echo "Using default: $povshare "
fi
povlib=$(pwd)
# I assume that you are already untar this in the right directory
echo "Where are the emacs libs, where you are going to extract this files?"
echo -n "I assume here, in $povlib >>> "
read povlib
if [ "$povlib" == "" ]; then
povlib=$(pwd)
echo "Using default: $povlib "
fi
#get rid of slashes
povshare=$(echo $povshare | sed -e "s|//* *\$||")
povlib=$(echo $povlib | sed -e "s|//* *\$||")
sed -e "s|SHARELIBSPOVRAY|$povshare|" \
-e "s|EMACSLISPLIBRARY|$povlib|" pov-mode.el > pov-mode-new.el
echo "I changed this: "
diff pov-mode.el pov-mode-new.el
echo -n "Can I overwrite pov-mode.el? "
read i
case $i in
y|Y) cp pov-mode.el pov-mode.el.backup
mv pov-mode-new.el pov-mode.el
*) echo "ok"
esac
exit 0
This should fix the vars. Of course you must follow the instructions here:
Feedback welcome!
Regards
Marco Pessotto
![](/i/fill.gif) |
