POV-Ray : Newsgroups : povray.unix : Animating on Linux Box Results in Speckles? (and Jitter=Off)! Server Time
23 Dec 2024 21:37:32 EST (-0500)
  Animating on Linux Box Results in Speckles? (and Jitter=Off)! (Message 1 to 3 of 3)
Subject: Animating on Linux Box Results in Speckles? (and Jitter=Off)!
Date: 2 Sep 2006 20:36:38
Message: <44fa2396$1@news.povray.org>
Hello everyone,
I'm running a gentoo box with the following version of POV-Ray:
Persistence of Vision(tm) Ray Tracer Version 3.6.1
(i686-pc-linux-gnu-g++ 3.4.6
 @ i686-pc-linux-gnu)
I've created a nice pie-chart that I'd like to animate. Rendering a
single frame is no problem -- the image looks acceptable. The problem
appears when I insert the clock. Actually, the problem appears on the
second frame and any subsequent frames in an animation.
I have some example images. For some reason frame 2 doesn't show up in
firefox when I load it. Perhaps this is somehow related to the problem.
It's as if the image is corrupt. I have zipped it and another viewer
should display it (KView works great).
good------> http://www.pfcme.org/pov/pie-slice1.png
speckled--> http://www.pfcme.org/pov/pie-slice2.png.zip
What follows is my pov source and ini files. Comments in the source are
from code I've found other places describing a solution to the problem I
thought I had. Before I list the code, thanks in advance for your
interest in my problem.
/Abe
=== INI
Antialias=On
Jitter=Off
Width=320
Height=240
Output_File_Type=N  #P[N]G format
#Bits_Per_Color=16
Palette=H  #[G]rayscale, [H]igh Color, [T]rue Color
Antialias_Threshold=0.9
Antialias_Depth=6
Sampling_Method=1
Input_File_Name=pie-slice.pov
Initial_Frame=1
Final_Frame=2#570
Initial_Clock=0
Final_Clock=3.14159
Cyclic_Animation=Off
Pause_when_Done=Off
=== POV
#include "shapes.inc"
// the camera: ----------
  angle    60
  location <0, 5, -10>
  right    x*image_width/image_height
  look_at  <0, 0, 0>
  rotate   <0, 0, -5>
//---------------------- end of camera
// now, some light
light_source {
  <-10,0,0>
  color rgb <0.5,0.5,0.5>
// now, some more light
light_source {
  <0,0,0>
  color rgb <0.75,0.75,0.75>
#declare BlurAmount = 0.1; // Amount of blurring
#declare S = seed(0);
// the pie
#declare pie_chart = union {
cylinder {
  <0,-.5,0>, <0, .5, 0>, 3
  finish {
    ambient 0.6
    specular 1.5
    reflection { 0.7 fresnel on }
    ior 1.5
  interior { refraction 0.5 }
normal { bumps BlurAmount
translate <rand(S),rand(S),rand(S)>*10
// scale 100 provides blurry and non-grainy reflections
// scale 0.001 provides grainy reflections
scale 100
  pigment { color rgbt <64/255,128/255,240/255,0.35> }
  double_illuminate
/*sphere {
  <0, 1, 0>, 0.15
  pigment { color rgb <1, 0, 0> }
// the pie piece
difference {
cylinder {
  <0,-.5,0>, <0, .6, 0>, 3.1
  finish {
    ambient 1.5
    specular 1.5
    ior 1.5
scale 100
  pigment { color rgbt <208/255,64/255,144/255, 0.45> }
  double_illuminate
plane {
<1, 0, 0>, 0
rotate <0, -72, 0>
plane {
<1, 0, 0>, 0
rotate <0, 90, 0>
no_shadow
rotate <0, -50, 0>
object {
  pie_chart
  rotate <-5*clock, -5*clock, -5*clock>
Subject: Re: Animating on Linux Box Results in Speckles? (and Jitter=Off)!
Date: 3 Sep 2006 09:26:17
Message: <pan.2006.09.03.13.26.13.385094@internode.on.net>
On Sat, 02 Sep 2006 20:37:45 +0000, Abe Mishler wrote:
> Hello everyone,
> /Abe
> === INI
> Antialias=On
> Jitter=Off
> Width=320
> Height=240
> #Bits_Per_Color=16
> Antialias_Depth=6
> Sampling_Method=1
> Initial_Frame=1
> Final_Frame=2#570
> Initial_Clock=0
> Final_Clock=3.14159
> Pause_when_Done=Off
> === POV
> camera {
>   angle    60
>   look_at  <0, 0, 0>
>   rotate   <0, 0, -5>
> // now, some light
> light_source {
>   <-10,0,0>
> light_source {
>   <0,0,0>
> // the pie
> cylinder {
>   finish {
>     ambient 0.6
>     specular 1.5
>     ior 1.5
> scale 100
>   double_illuminate
> /*sphere {
>   <0, 1, 0>, 0.15
> // the pie piece
> difference {
> cylinder {
>   finish {
>     ambient 1.5
>     specular 1.5
>     ior 1.5
> scale 100
>   double_illuminate
> plane {
> <1, 0, 0>, 0
> rotate <0, -72, 0>
> plane {
> <1, 0, 0>, 0
> rotate <0, 90, 0>
> no_shadow
> rotate <0, -50, 0>
> object {
>   pie_chart
I tried your files and got the same result except I could open the
pictures in firefox-1.5.0.5.
Oddly, the first render looked ok and the others were speckled even
without the rotate.
When I changed the planes to
plane
   <1, 0, 0>, 0.01
   rotate <0, -72, 0>
plane
   <1, 0, 0>, 0.01
   rotate <0, 90, 0>
the problem went away.
Cheers,
   PoD.
Date: 3 Sep 2006 12:48:44
Message: <44fb076c$1@news.povray.org>
>> Hello everyone,
>> /Abe
>> === INI
>> Antialias=On
>> Jitter=Off
>> Width=320
>> Height=240
>> #Bits_Per_Color=16
>> Antialias_Depth=6
>> Sampling_Method=1
>> Initial_Frame=1
>> Final_Frame=2#570
>> Initial_Clock=0
>> Final_Clock=3.14159
>> Pause_when_Done=Off
>> === POV
>> camera {
>>   angle    60
>>   look_at  <0, 0, 0>
>>   rotate   <0, 0, -5>
>> // now, some light
>> light_source {
>>   <-10,0,0>
>> light_source {
>>   <0,0,0>
>> // the pie
>> cylinder {
>>   finish {
>>     ambient 0.6
>>     specular 1.5
>>     ior 1.5
>> scale 100
>>   double_illuminate
>> /*sphere {
>>   <0, 1, 0>, 0.15
>> // the pie piece
>> difference {
>> cylinder {
>>   finish {
>>     ambient 1.5
>>     specular 1.5
>>     ior 1.5
>> scale 100
>>   double_illuminate
>> plane {
>> <1, 0, 0>, 0
>> rotate <0, -72, 0>
>> plane {
>> <1, 0, 0>, 0
>> rotate <0, 90, 0>
>> no_shadow
>> rotate <0, -50, 0>
>> object {
>>   pie_chart
> without the rotate.
> plane
>    <1, 0, 0>, 0.01
>    rotate <0, -72, 0>
> plane
>    <1, 0, 0>, 0.01
>    rotate <0, 90, 0>
> Cheers,
>    PoD.
It works great. Thanks a bunch!
