![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I posted an "idea" about povray and knoppix and was suggested to file a bug
report. It's #2 for the 4.0 DVD!
http://www.knoppix.net/wiki/Bugs/4.0
http://www.knoppix.net/forum/viewtopic.php?p=88147#88147
I may have done a service to povray or I may have tried to remake it in my
own image in a very annoying way. Maybe both.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I doubt if you did any disservice, and if Knoppix adds PovRay so it works
out of the box, then you've probably accomplished something, but I don't
think its a Knoppix problem. I had the same issue with Slackware.
KPovModeler seems to ship with KDE and get installed with it whether there
is a PovRay available or not. Since I was installing PovRay anyway, no
biggie, but it was annoying to have it on the menu but not able to use it.
(And after trying KPovModeler I decided it only had a couple useful tools
anyways)
RG
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> anyways)
I believe the problem is that the POV-Ray redistribution licence is
_slightly_ incompatable with the DFSG [Debian Free Software Guidelines] --
which makes distribution slightly difficult; haven't you noticed how there
isn't a pov-ray package for Debian that is any newer than 3.5? Debian
_does_ have a tendency to try and maintain patches and build it's own
packages from source...
That said, I don't think Ubantu would mind distributing the latest and
greatest POV-Ray packages; it has [among other things] mplayer binaries,
and everything else under the sun, it seems... -- Thing is, IIRC, Ubantu
packages don't always work on Debian; I don't use Ubantu myself.
AFAIK, it might be easier for Knoppix to use one of those dynamic
install-in-ramdisk scripts for POV-Ray (to get around distribution issues)
and download the latest POV-Ray from the site, and automate the install for
the user. Doesn't sound too hard [provide a GUI, check for connection,
download, untar/gz, execute install under sudo, execute install user/kde
under sudo]. Would allow you to squeeze it onto the Knoppix CD too,
possibly.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmm... I primarily use RedHat Fedora, but "dabble" with other distros,
including Debian 3.1 (Sarge). I simply downloaded the Linux POVRay
package directly from povray.org and did a normal install with that.
Version 3.6.1 installs properly and runs fine. Although I confess I
haven't done anything more than a few test renders (from the standard
"Scene" examples), simply to verify that it does work.
Of course, I can't say anything about Knoppix, but 3.6.1 is okay with
standard Debian.
-=- Larry -=-
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually, the reason seems to be more the lack of a competent maintainer
with sufficient time. For example the "POV-Ray 3.5" Debian distributes
contains broken patches and untested code. And before that they distributed
(and still do it seems) a completely outdated POV-Ray 3.0 with completely
obsolete patches added to it, i.e. the macro patch - obsolete since POV-Ray
3.1 and not even remotely compatible with any official version of POV-Ray.
In short, the POV-Ray versions Debian distributes are basically useless.
Unfortunately, pointing this out to the current Debian maintainer (see the
bug reports) had no effect whatsoever :-(
As such, it can only be recommended to use the official POV-Ray rather than
the broken versions Debian distributes, even in case of POV-Ray 3.5 or
POV-Ray 3.0!
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
Visit POV-Ray on the web: http://www.povray.org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
