POV-Ray : Newsgroups : povray.unix : WxPyvon : new POVRAY Editor for Linux Server Time
28 Sep 2024 20:50:07 EDT (-0400)
  WxPyvon : new POVRAY Editor for Linux (Message 1 to 8 of 8)
Subject: WxPyvon : new POVRAY Editor for Linux
Date: 30 May 2005 22:32:46
Message: <429bccce@news.povray.org>
Hi you all,
Some of you may have used Pyvon ( a POV-RAY editor for Linux) sometime ago.
Due to lack of time (and others plans in life), I more or less dropped
the development of Pyvon.
2 months ago, I restarted to write it from scratch, this time using a
more elaborate wrapper : wxPython (-> hence the name :).
It is now completely useable (just a few things are still disabled)
It makes extensive use of Scintilla -> WxPvyon feature syntax
highlighting and word completion.
WxPyvon has more or less the same layout as Pyvon plus a couple of nice
features.
- On Kde render window can be kept on top.
(Does anyone know how to launch an app on top on gnome, windowmaker,...)
- Magnify or unmagnify the current window
It requires :
python (I use version 2.4)
wxpython 2.5.3
try to install psyco (but it should work without it)
How to run it :
Once you have unpacked it just cd to the directory and type python b60.py
A few things still need some work :
insert does not work
directives still need some work
add a Todo list
As always, comments, found bugs, suggestions ... are welcome
I hope you will enjoy it
Fabien
to reply remove '_nospam_'
Download 'wxpyvon_b60.tar.gz' (72 KB)
Subject: Re: WxPyvon : new POVRAY Editor for Linux
Date: 30 May 2005 22:59:33
Message: <429bd315@news.povray.org>
I forgot to add the current directory :
use the file inclosed instead
fabien HENON wrote:
> Hi you all,
> features.
> It requires :
> wxpython 2.5.3
> How to run it :
> add a Todo list
> Fabien
Download 'us-ascii' (27 KB)
Date: 31 May 2005 18:15:21
Message: <429ce1f9$1@news.povray.org>
Found a bug in the render on top option. It is better not to use it for
the time being
fabien HENON wrote:
> Hi you all,
> features.
> It requires :
> wxpython 2.5.3
> How to run it :
> add a Todo list
> Fabien
Date: 1 Jun 2005 04:25:34
Message: <429d70fe$1@news.povray.org>
	Hi Fabien,
	Please do not post attachments in this group.  You shall
consider the binary groups instead, or, even better, post your
new pyvon versions on your sourceforge account  :-)
	Thanks!
	- NC
Date: 1 Jun 2005 22:20:50
Message: <429e6d02$1@news.povray.org>
As a Linux newbie with a few dozen distros at his fingertips,  I can say
that I do indeed "have" python, but I have no idea what to do with your
script.  Do I compile it once with python, invoke it everytime like I might
if I had Java installed, etc.??
"fabien HENON" <fabienhenon_nospam_@free.fr> wrote in message
news:429bccce@news.povray.org...
> Hi you all,
> ago.
Date: 2 Jun 2005 07:17:56
Message: <429eeae4@news.povray.org>
  Just run it? There's an executable named b60.py there.
Date: 2 Jun 2005 12:46:00
Message: <429f37c8$1@news.povray.org>
I Greg,
here is the recipe :
- open a terminal ( ie konsole,xterm,...) in kde, gnome, ....
- untar the tgz file in the directory ( or use konqueror to unpack it
where you want)
- once the file 'untargzed', go to the directory in which is was 'untargzed'
- type 'python b60.py'
To avoid a bug just disable the render on top options.
Hope this helps
Fabien
>>Hi you all,
>>ago.
Date: 23 Oct 2006 16:25:00
Message: <web.453d243f24bb0ffb93bb3e00@news.povray.org>
If you can get this to work under Ubuntu, let me know.
I have all the dependencies satisfied, and all I get is a compile error.
