POV-Ray : Newsgroups : povray.unix : how to WINE win versions of povray Server Time
10 Jun 2026 16:09:52 EDT (-0400)
  how to WINE win versions of povray (Message 1 to 5 of 5)
Subject: how to WINE win versions of povray
Date: 6 May 2005 16:48:51
Message: <427bd833$1@news.povray.org>
I put a live Linux CD into a win box and then tried:
right click on WINE (menu optoin in KDE)
"Put Into Run Dialog"
wine  /mnt/hda1/povray/bin/pvengine.exe
get error: cannot find home entry in registry.
I know other means of using povray have been discussed here, but I just
tried this on a whim on a PC that ain't connected to internet.
Is there a syntax for WINE that *would* work?
Subject: Re: how to WINE win versions of povray
Date: 6 May 2005 16:55:02
Message: <d5glie$e4v$1@chho.imagico.de>
AFAIK WinPOV has to be installed before use - try running the install
program.
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 6 May 2005 17:02:54
Message: <427bdb7e$1@news.povray.org>
Just to make sure, I mean that there was an extant, working version of
povray on the PC for years.  I just tried WINE with a linux live CD.  Do you
mean that I have to (re) install from WINE, then invoke again?
news:d5glie$e4v$1@chho.imagico.de...
> program.
Date: 6 May 2005 17:18:06
Message: <427bdf0e@news.povray.org>
> "Christoph Hormann" <chr### [at] gmxde> wrote in message
>>program.
run : 'wine /path/where/povwin.exe/is/located'
then run something like : 'wine .wine/drive_c/Program
Files/path/to/the/pvengine.exe' file
./wine is a hidden directory
Fabien
Date: 6 May 2005 19:49:37
Message: <427c0291@news.povray.org>
1st you'll have to install povwin using wine:
(If povwin36.exe is located (p.e.) in /home/greg/downloads)
open a console and type:
cd downloads
wine povwin36.exe
The installation window should open (like in Windows). Follow the steps
you already know to install it.
Important: Accept the default location for installation; C:\Program
Files\POV-Ray for Windows v3.6.
The installation should end with a test render (exactly the same as in
Windows).
Then if you want to run povray for windows the command to run is:
wine "C:\Program Files\POV-Ray for Windows v3.6\bin\pvengine.exe"
And that's all.
Hope this helps
________________________
Txemi Jendrix
www.txemijendrix.com
