POV-Ray : Newsgroups : povray.unix : Cygwin configure error Server Time
10 Jun 2026 17:35:55 EDT (-0400)
  Cygwin configure error (Message 1 to 10 of 16)
Subject: Cygwin configure error
Date: 9 Sep 2004 17:07:18
Message: <4140c606$1@news.povray.org>
Has anyone managed to get Povray 3.6.1 to build under Cygwin? Configure
fails for me:
creating Makefile
creating jconfig.h
configure.gnu: editing Makefile
configure: configuring in libraries/tiff
configure: running /bin/bash './configure.gnu' --prefix=/usr/local
'COMPILED_BY=Ross Smith <ros### [at] pharosconz>' --cache-file=/dev/null
--srcdir=.
configure.gnu: configuring libtiff 3.6.1
configure.gnu: running ./configure --noninteractive --with-DSO=no
--prefix=/usr/local     --srcdir=.
Configuring TIFF Software v3.6.1
If configure does the wrong thing, check the file config.log for
information that may help you understand what went wrong.
Reading site-wide parameters from ./config.site.
Here we are again, this time on a i686-pc-cygwin system.
Cannot locate a working ANSI C compiler.
We attempted to compile the following test program:
main(int argc, char* argv) { exit(0); }
with these compilers:
      gcc
but none of them were successful.
If your compiler is in a non-standard location, you can specify its
location in several ways:
     o set the environment variable CC
     o create a config.local or config.site file that includes a
       definition for CC
     o supply it on the command line using -with-CC=<pathname>
If command line options are required for ANSI C compilation, set the
ENVOPTS parameter to these options in a similar way (either through
an environment variable or config.local/config.site) and then rerun
this script.
configure:
configure: Unrecoverable error!  Once you've corrected the problem rerun
this script.
POV-Ray 3.6.1 has been configured with the following features:
   I/O restrictions: enabled
   X Window display: enabled
   SVGAlib display : disabled
Type 'make' to build, and 'make install' to install all files in the
hierarchy
/usr/local
Ross Smith ...................... Pharos Systems, Auckland, New Zealand
"Carelessly planned projects take three times longer to complete than
expected. Carefully planned projects take four times longer to
complete than expected, mostly because the planners expect their
planning to reduce the time it takes." -- Anon.
Subject: Re: Cygwin configure error
Date: 9 Sep 2004 18:19:46
Message: <4140d702$1@news.povray.org>
	Yes, as cygwin was part of my various testing platforms  :-)
> [snip]
	I once or twice faced this situation, but cannot remember now
what was the precise cause.  Please send me or post the following file:
libraries/tiff/config.log
	Thanks,
	- NC
Date: 9 Sep 2004 19:41:14
Message: <4140ea1a$1@news.povray.org>
>> [snip]
>     Thanks,
>     - NC
Fri Sep 10 09:04:08 NZST 2004
Running ./configure with arguments: --noninteractive --with-DSO=no
This file contains information that is captured from running the configure
script.  Lines that begin with a "+" are command lines echoed by the
shell.  Other lines are the output of commands; usually the contents of
test case files or the output from compilers.  If configure does the
wrong thing, you can use the information captured here to aid in debugging.
+ . ./config.site
+ cat dummy.c
+ cat xgnu.c
#ifdef __GNUC__
yes;
#endif
+ gcc -E xgnu.c
+ egrep yes
yes;
+ gcc -o dummy -I.././../jpeg -L/usr/X11R6/lib dummy.c
Date: 11 Sep 2004 13:18:20
Message: <4143335c$1@news.povray.org>
	I'm suprised you don't get any warning or error message after
this last line (maybe you did miss it when copying-pasting the
file content...).
	While I cannot test at the moment, I kinda remember that this
test can fails because of the dummy.c file created by the libtiff's
configure:
	It should have a "#include <stdlib.h>" before main().  Here,
it's likely that gcc cannot find stdlib.h and fails to compile dummy.c
because of the call to  exit().  That somehow tells you have a problem
with your Cygwin installation (however libjpeg apparently was correctly
configured, right ?).
	You might try to configure libtiff alone, passing LDFLAGS
that contains the path to the stdlib.h header, usually /usr/local/include
cd libraries/tiff
./configure LDFLAGS=/usr/local/include
	I know it's weird to pass LDFLAGS here (and I don't guaranty it
will solve the problem), but libtiff is weird anyway  ;-)
	- NC
Date: 12 Sep 2004 17:39:24
Message: <4144c20c$1@news.povray.org>
> file content...).
> configure:
How do you make that out? I can't see how it's a problem with Cygwin
if it fails to compile an invalid program.
Sorry, I don't know enough about the configure process to answer that.
Why is it trying to build libjpeg and libtiff anyway? Cygwin already
has them.
> cd libraries/tiff
Doesn't work:
      gcc
       definition for CC
this script.
configure:
this script.
Date: 12 Sep 2004 18:33:16
Message: <4144ceac$1@news.povray.org>
	Please try to run the following:
echo "main(int argc, char* argv) { exit(0); }" > dummy.c
gcc -o dummy dummy.c
	It should report an error if there is a problem with the
Cygwin installation (such as some missing devel package maybe).
In this case, please run again gcc, this time with:
gcc -v -o dummy dummy.c
	and report all the console messages that you get.
	The best would be to send me the config.log file you get in
the main POV-Ray source tree, as well as that of the support library
that is has configured.  You can find all those config.log files
running the following command:  find -type f -name config.log
You should get a subset of:
./config.log
./libraries/zlib/config.log
./libraries/png/config.log
./libraries/tiff/config.log
./libraries/jpeg/config.log
	Please send me all of those files.
> has them.
	This is answered if you look at what POV-Ray's configure outputs
on the console.  Hint: look at the library versions.  In case of cygwin,
libjpeg is always built, forcing libtiff to build as well.  There are
good reasons for that.
> Doesn't work:
	Yes, sorry I did a small mistake.  Try again with:
./configure LDFLAGS=-I/usr/local/include
	but honestly I don't think it will work either.  That's why I'd
like to get your log files to check things carefully.  Thanks.
	- NC
Date: 12 Sep 2004 19:21:33
Message: <4144d9fd$1@news.povray.org>
This runs without complaint. (I'd forgotten how permissive GCC
is in its default mode; I always turn up the warnings to 11 on
my own code.)
Reading specs from /usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/specs
Configured with: /gcc/gcc-3.3.3-3/configure --verbose --prefix=/usr
--exec-prefix=/usr --sysconfdir=/etc --libdir=/usr/lib
--libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info
--enable-languages=c,ada,c++,d,f77,java,objc,pascal --enable-nls
--without-included-gettext --enable-libgcj --with-system-zlib
--enable-interpreter --enable-threads=posix --enable-java-gc=boehm
--enable-sjlj-exceptions --disable-version-specific-runtime-libs
--disable-win32-registry
Thread model: posix
gcc version 3.3.3 (cygwin special)
  /usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/cc1.exe -quiet -v -D__GNUC__=3
-D__GNUC_MINOR__=3 -D__GNUC_PATCHLEVEL__=3 -D__CYGWIN32__ -D__CYGWIN__
-Dunix -D__unix__ -D__unix -idirafter
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/../../../../include/w32api
-idirafter /usr/local/lib/../../include/w32api dummy.c -quiet -dumpbase
dummy.c -auxbase dummy -version -o
/cygdrive/d/DOCUME~1/rosss/LOCALS~1/Temp/ccNfogM4.s
GNU C version 3.3.3 (cygwin special) (i686-pc-cygwin)
         compiled by GNU C version 3.3.3 (cygwin special).
GGC heuristics: --param ggc-min-expand=99 --param ggc-min-heapsize=131004
ignoring nonexistent directory "/usr/i686-pc-cygwin/include"
ignoring duplicate directory "/usr/local/include"
ignoring duplicate directory "/usr/include/w32api"
#include "..." search starts here:
#include <...> search starts here:
  /usr/local/include
  /usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/include
  /usr/include
  /usr/include/w32api
End of search list.
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/../../../../i686-pc-cygwin/bin/as.exe
--traditional-format -o
/cygdrive/d/DOCUME~1/rosss/LOCALS~1/Temp/ccUSHyX7.o
  /usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/collect2.exe -Bdynamic
--dll-search-prefix=cyg -o dummy.exe
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/../../../crt0.o
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/crtbegin.o -L/usr/local/lib
-L/usr/lib/gcc-lib/i686-pc-cygwin/3.3.3
-L/usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/../../..
/cygdrive/d/DOCUME~1/rosss/LOCALS~1/Temp/ccUSHyX7.o -lgcc -lcygwin
-luser32 -lkernel32 -ladvapi32 -lshell32 -lgcc
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/crtend.o
> ./config.log
Mailed separately.
>> has them.
It doesn't say anything about version numbers. The relevant
output (I think) is:
Libraries
checking whether to enable static linking... no
checking for sin in -lm... yes
checking for asinh... yes
checking for vga_init in -lvga... no
configure: SVGAlib display will be disabled
checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for XFlush in -lX11... yes
checking for XpmCreatePixmapFromData in -lXpm... yes
checking whether to enable the watch cursor... no
checking for installed supporting libraries... yes
checking for library containing zlibVersion... -lz
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for libz version >= 1.2.1... 1.2.1, ok
checking for library containing png_get_libpng_ver... -lpng12
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
checking for libpng version >= 1.2.5... 1.2.5, ok
checking for libjpeg... forced by cygwin
configure: libjpeg will be built and statically linked to POV-Ray
checking for libtiff... forced by libjpeg
configure: libtiff will be built and statically linked to POV-Ray
>> Doesn't work:
Nope.
Date: 13 Sep 2004 04:43:31
Message: <41455db3@news.povray.org>
i was able to compile Povray 3.6.1 under cygwin. Cygwin was a fresh
installation with ALL modules.
(Latest version of cygwin)
With the default installation of cygwin there was no C99 compatibility
(compiling failed due missing
vsnprintf()? function)
1st try failed because the source files were in a directory with spaces
	C:\Programme\POV-Ray for Windows v3.6\cygwin\povray-3.6.1
2nd try with
	D:\local_dev\Privat\cygwin\povray-3.6.1
was successful.
The same applies with megapov 1.1 sources.
After compiling i 've tried some test renders -> no problems (there was
some difficulties with the path to the .ini files).
Sorry for my poor english...
Hope, this helps...
Zan
PS.: for valid email adress, please remove "REMOVE"
>fails for me:
>creating Makefile
>creating jconfig.h
--srcdir=.
>      gcc
>       definition for CC
>this script.
>configure:
this script.
D========================
D====
hierarchy
>/usr/local
D====
Date: 13 Sep 2004 06:17:13
Message: <414573a9$1@news.povray.org>
	Mmmh this is getting interesting  ;-)
	Did you run a bash or (t)csh shell for doing this test ?
It could be that the environment is different than when running
the libtiff configure (but I don't think it is).
	Okay, you probably have (one of) the latest cygwin release(s).
>  /usr/local/include
>  /usr/include
>  /usr/include/w32api
	Looks okay indeed.
> Mailed separately.
	Thanks, I'm gonna inspect this today.
	So it corresponds to what I wrote before.
	Hopefully, with the help of your log files I'll get an idea
of what's going on.  Unfortunately I don't have cygwin again today,
so that'll be somewhat harder to do some real testing.
	- NC
Date: 13 Sep 2004 06:22:02
Message: <414574ca$1@news.povray.org>
> With the default installation of cygwin there was no C99 compatibility (compiling
failed due missing
	POV-Ray's configure didn't complain it cannot find vsnprintf() ?
Normally it should.
	Yes, that's an usual Cygwin problem.  My testing environment was
also including paths with spaces to try to cope with this as much as
possible, but apparently I still missed some cases.
	Could you send me the various config.log files you obtained in
this situation ?
	That's expected  :-)
> (there was some difficulties with the path to the .ini files).
	Please describe this problem.
	Thanks,
	- NC
