POV-Ray : Newsgroups : povray.unix : [announce] JITC: Really fast POVRay FPU Server Time
21 Apr 2025 15:49:30 EDT (-0400)
  [announce] JITC: Really fast POVRay FPU (Message 1 to 1 of 1)
Subject: [announce] JITC: Really fast POVRay FPU
Date: 3 Aug 2004 18:11:15
Message: <41100d82@news.povray.org>
Hello all...
the last two days, I wrote a patch for UNIX POVRay-3.6. to speed
up user-functions as used e.g. in isosurfaces.
Instead of interpreting the functions as done by the POV VM, this
patch does just-in-time compilation of the function using the system
compiler -- all that on-the-fly completely transparent for the user.
Result: Some scenes trace 4 times as fast!
Details:
http://www.cip.physik.uni-muenchen.de/~wwieser/render/povray/patches/jitc-patch/
Disclaimer:
- The patch is Linux-specific. Probably Minor efford porting to other UNICes
- The patch is _highly_experimental_. It works fine for me but I expect that
- The patch is not cleanly designed in several points. Unfortunately, during
Any comments welcome.
Wolfgang
Subject: Re: [announce] JITC: Really fast POVRay FPU
Date: 3 Aug 2004 18:14:47
Message: <41100e57@news.povray.org>
In article <41100d82@news.povray.org> , Wolfgang Wieser
You are aware that the official POV-Ray for Mac OS does include a
just-in-time compiler, aren't you?
    Thorsten
e-mail: tho### [at] trfde
Date: 3 Aug 2004 18:27:35
Message: <41101157$1@news.povray.org>
	It's very likely Wolfgang never tried the Mac OS version  ;-)
	Sounds like a cool patch anyway !
	- NC
Date: 3 Aug 2004 18:39:20
Message: <41101418@news.povray.org>
In article <41101157$1@news.povray.org> , Nicolas Calimet
That is true, but using the core code SYS_FUNCTIONS macro family would have
made integration of a JIT compiler possible without hacking fnpovfpu.cpp.
In particular because they are documented to exist exactly for that purpose.
Would at least have made the whole implementation easier...
Certainly!  On the other hand, calling gcc is overkill to make JIT
compilation possible :-)
    Thorsten
Date: 3 Aug 2004 19:12:52
Message: <41101bf4$1@news.povray.org>
haven't tried it myself, but........ wow!
Date: 3 Aug 2004 19:14:53
Message: <41101c6d@news.povray.org>
otherwise encorporate the whole gcc thing in pov-ray. probably impossible
because of licensing issues.
Date: 4 Aug 2004 01:40:01
Message: <cepsnj$260$1@chho.imagico.de>
Wolfgang Wieser wrote:
> Hello all...
I think the work probably would have been better invested in
implementing an internal JIT compiler using the existing hooks as
Thorsten explained.  This would work on all x86 systems (and for Mac an
implementation already exists).
BTW your page does not say which optimizations you used for compiling
the patched version.  To me it seems quite unlikely that you always get
a speedup, there is also some overhead introduced by calling an external
library.
None the less an interesting idea of course.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 4 Aug 2004 05:29:29
Message: <4110ac78@news.povray.org>
Sounded interesting. I'll have a look at that.
Why didn't anybody put that on a publically available todo list? ;)
Well, this actually does not matter much. As pointed out on my home page,
I used the same compiler flags for the patched and the unpatched version
to make sure that the timings can be compared. And of course, I used the
best ones I know.
-O2 -ffast-math -march=athlon-xp -Wno-multichar -finline-functions
-funit-at-a-time -fno-rtti -mfpmath=387
> library.
This is correct. An external no-op function called via a pointer takes
about 10 times as long as an internal no-op function.
No-op function means:
  int foo(int x)  {  return(x);  }
But we should not forget that the huge swith-case construct in the main VM
takes some time, too. And this switch is effectively eliminated by JITC.
Wolfgang
Date: 4 Aug 2004 05:33:53
Message: <4110ad81@news.povray.org>
Actually, I was not aware of that! I'll have a look.
Thanks for the hint.
Wolfgang
Date: 4 Aug 2004 05:41:49
Message: <7lb1h0pgvjkebk6e6ofo9a8hvdt5b07nt1@4ax.com>
On Wed, 04 Aug 2004 11:28:22 +0200, Wolfgang Wieser <wwi### [at] nospamgmxde>
I have considered this task for the future versions of MegaPOV thought I would
be veeeeery happy if you could be faster :-)
ABX
