![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
gRRominet has released the 0.2.2b beta :
http://sourceforge.net/project/showfiles.php?group_id=92021
ZeSly
http://perso.wanadoo.fr/zesly/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for the info!
Florian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I was unable to connect to the news and that's why I've ask ZeSly to
tell you about this new version. I already have found a few bugs in this
new feature and these will be corrected in the final v0.2.2.
Additionaly, you'll find a documentation on the website and in the
"Ressources" directory of the package (and that would be fine if you
could help me to correct it).
Thierry
> Florian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
already known bugs (corrected for the final version) :
- completion for key-words does only works on new files
- completion doesn't work when there is a #
- another one, but I can't remember ;-P
> Thierry
>> Florian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
From gRRominet :
the stable release of qtpoveditor v0.2.2 has been published.
http://qtpoveditor.sf.net
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
However, I got some problems running it with Povray 3.6b1:
This is the output of POV-Ray when a render is started via QtPOVEditor:
Parsing Options
Input file: +MV3.5 +Q9 +W1024 +H768 +B001 +Ocircles.pov.png
+GA/tmp/povrendering_log2455 +P circles.pov (compatible to version 3.60)
Remove bounds........On
Split unions.........Off
0:00:00 Parsing
Possible Scene File Parser Initialization Error: Could not find file '
+MV3.5
+Q9 +W1024 +H768 +B001 +Ocircles.pov.png +GA/tmp/povrendering_log2455 +P
circles.pov'
Scene File Parser Initialization Error: Cannot open input file.
Somehow it won't take the correct input file, but I don't know why.
Anybody else got this problem? If I start the render from the command
line (without QTPOVEditor), with the same arguments, it works o_O
BTW: Using 3.5 everything works fine, so I'll use this till I find the
source of the problem ;)
Florian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"ZeSly" <zes### [at] wanadoo fr> wrote in message
news:40197d3f$1@news.povray.org...
I messed with it a bit and like some of the new functionality. I am
still using 1.4 until proper tabs are re-implemented, however.
-Shay
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It seems that the last functionnality have destroyed the "automatic"
tabulation mode ... I'll correct this as soon as possible.
=> ooops ... I have forget to do this :-/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"gRRosminet" <pov### [at] les-charles net> wrote in message
news:4023c04d@news.povray.org...
Thanks for all of the work on the editor. I'm still hoping for the
return of true tabs instead of spaces.
-Shay
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
