POV-Ray : Newsgroups : povray.unix : compiling 3.5 with debug info ? Server Time
31 Mar 2026 06:38:17 EDT (-0400)
  compiling 3.5 with debug info ? (Message 1 to 7 of 7)
Subject: compiling 3.5 with debug info ?
Date: 27 Jul 2003 06:51:22
Message: <3f23aeaa@news.povray.org>
EHLO
did you know a way to go thru the
    $ ./configure
    $ make
way, and adding the -g option needed
for gdb ?
Th.
Subject: Re: compiling 3.5 with debug info ?
Date: 27 Jul 2003 07:39:18
Message: <3f23b9e5@news.povray.org>
Thierry Boudet wrote:
> EHLO
>     $ ./configure
>     $ make
> for gdb ?
> Th.
what does ./configure --help say? there is probably an option
--enable-debug=yes for configure.
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 27 Jul 2003 08:41:01
Message: <3f23c85d$1@news.povray.org>
>>EHLO
>>    $ ./configure
>>    $ make
>>for gdb ?
>>Th.
    Yes, I've just try it now.
    No debug flag :)
c++ -DPREFIX=\"/usr/local\"
-DPOV_LIB_DIR=\"/usr/local/share/povray-3.5\"
-DCOMPILER_VER=\".Linux.gcc\" -DSYSCONFDIR=\"/usr/local/etc\"
-DUSE_IO_RESTRICTIONS=\"\"     `if [ "Xgcc" = "Xgcc" ]; then echo
"-Wno-multichar"; fi ` -O3 -finline-functions -ffast-math
-fomit-frame-pointer -funroll-loops -fexpensive-optimizations
-malign-double -foptimize-sibling-calls -minline-all-stringops
-Wno-multichar -c bezier.cpp
   Th.
Date: 27 Jul 2003 08:57:49
Message: <3f23cc4d@news.povray.org>
Looks like this configure doesn't support it then. Maybe you can do it "by
hand" by edition the Makefile in the src/ directory and add "-g" to the
CPPFLAGS.
Date: 27 Jul 2003 16:30:49
Message: <3f243679@news.povray.org>
Hash: SHA1
>     No debug flag :)
debug is not a feature that can be set when building POVRay.  The safest
way to have a flag passed to the compiler, linker, etc. is to set the
appropriate FLAGS environment variable before running configure (in this
case setting CPPFLAGS).  Something like this should do the trick:
export CPPFLAGS="-g"
./configure --with-x # any other flags go here too
BEWARE: if you are using gcc, this will not turn off optimization.
POVRay is being compiled with -O3, the highest level of speed
optimization available on gcc.  In some cases, the code actually
generated may look very different from the original source as loops are
unrolled, function inlined, etc.
Good Luck,
  Karmix
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.7 (GNU/Linux)
iD8DBQE/JC8Z8/zoYc8slRERAs65AJ9Mwe1Xh1eLTWpTS8UpkxuybcJeewCZAcFi
hreb2YzEI+sonf6BiAV+1mQ=
=XECj
-----END PGP SIGNATURE-----
Date: 28 Jul 2003 21:02:20
Message: <pan.2003.07.29.01.02.43.643976@gentoo.org>
>     No debug flag :)
First:
be aware that -fomit-frame-pointer invalidates debugging (makes it
impossible in fact) on x86
Also, I'd suggest you use :
CFLAGS="-march=i686 -g -O3"  CXXFLAGS="${CFLAGS} ./configure
on a clean set of sources, a check inside the config.log should show that
it compiles the test-programs with the right flags. Of course, the
-march=i686 is just a recommendation (take your normal ones here)
also, make sure you don't strip the binary.
//Spider
begin  .signature
This is a .signature virus! Please copy me into your .signature!
See Microsoft KB Article Q265230 for more information.
end
Date: 14 Aug 2003 05:18:24
Message: <3f3b53e0@news.povray.org>
> CPPFLAGS.
It's CXXFLAGS, not CPPFLAGS.
It's recommended to use
./configure CFLAGS="-g -O -blah" CXXFLAGS="-g -O -blah -blah"
For good debugging, leave away any optimization flags.
Wolfgang
