Hello all!
Sorry, but I don't speak english very good...
I need to redirect POV-Ray output to a textfile, but I can't do it with
traditional methods:
echo "Hello world">textfile
When I use a same sintax to POV-Ray, the output file will be empty.
I will use it to work POV-Ray + Perl + PHP scritps...
Thanks!!!!
É isso aí...
Márcio Pessoa
mar### [at] lc3 com br
Linux Registred User # 280238
Visite: http://www.lc3.com.br/
Hi.
POV-Ray manual says:
Redirecting options:
GI<name> or Create_Ini=bool or Create_Ini=file
Write all INI parameters to a file named after the input scene
file, or one with the specified name.
G[ADFRSW]<name> or <Stream>_File=bool or <Stream>_File=file
Write the stream to the console and/or the specified file.
The streams are All_File (except status), Debug_File,
Fatal_File, Render_File, Statistics_File,
and the Warning_File.
So to redirect output try this:
povray <some_options> -GAtextfile
A.
(Mex) Márcio Pessoa wrote:
> Hello all!
> Thanks!!!!
> É isso aí...
> Márcio Pessoa
try using +GA as in : povray +iscene.pov .... +gatextfile
Fabien H
povray > textfile 2>&1
will do the trick.
Wolgang
